Old 11-14-2016, 05:51 PM   #1
06.325ci
My Ride: 2006 325ci
Loud Humming From Engine Bay.?
Soo In the Video i would put key in ignition on the 2nd position and the noise occurred, and then once running turn car off and it begins again. Only lasts about 10 seconds max. Any ideas?
Last edited by 06.325ci; 11-14-2016 at 05:52 PM. Reason: Accidentally put two videos
06.325ci is offline   Reply With Quote
Old 11-14-2016, 07:02 PM   #2
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
Why don't you pop the hood, have someone else do what you did with the key and stand over the engine to pinpoint the noise?
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 11-14-2016, 09:39 PM   #3
Nicker
My Ride: 323ci
my car has been making that cyclops android killer noise forever, I hope nothing is broken!
00' 323ci - 170hp
Nicker is offline   Reply With Quote
Old 11-14-2016, 11:43 PM   #4
06.325ci
My Ride: 2006 325ci
I did , and the noise is coming directly above the engine , above intake manifold. Does that help narrow it down?
Old 11-15-2016, 03:36 PM   #5
06.325ci
My Ride: 2006 325ci
Anyone ?
Old 11-15-2016, 03:39 PM   #6
Spannerhead
Save the Manuals!
Secondary air pump?
Mine made an awful whine until I replaced the mounts, now I can barely hear it.
It doesn't come on when the engine is off though. Only 30 seconds or so on cold startup.
Old 11-16-2016, 03:22 AM   #7
BiH55
My Ride: 2001 bmw 325i
Probably an air pump
BiH55 is offline   Reply With Quote
Old 11-16-2016, 09:19 AM   #8
E46Envyy
My Ride: 04 330ci Auto
I know the ecu box has a cooling fan. It seems to run for about 10sec after the car is off. The SAP only runs when the car is running for the initial 30seconds to help the cats get up to temp.
Nothing located inside the engine would still be running once the car is off.
I think this sound is normal, nothing to worry about.
E46Envyy is offline   Reply With Quote
Old 11-16-2016, 02:47 PM   #9
Jason325xi
My Ride: 2004 325xi 5speed
could be a noisy blower?
Adjustable koni yellow front struts, Rob43 9-way adjustable rear shocks, Special Rob43 lowering springs, supreme power drop hats, billet aluminum rear shock mounts, poly RTAB, G.A.S. Disa kit, G.A.S. 1.2bar expansion tank cap
I run 6010 overhead in a t-shirt!
Jason325xi is offline   Reply With Quote
engine bay, humming, noise, uncommon
