Old 12-07-2016, 12:09 AM   #1
giovannijones
My Ride: 2001 Bmw 325 Ci
BMW E46 Rough Idle hesitation
Hey I have a 2004 BMW 330ci .
Recently I realized my vehicle has been having rough idle and hesitation. Took it to the shop and they replaced the plugs , fuel filter and maf sensor . They also smoked the vehicle and it has no vacuum leaks on it . It has 110,000 miles . A chrck engine light came on a while back and here's the data from it .
P0420
P0430
P2227
Freeze data
Shrt fuel trim 1= 0.8%
Long fuel trim 1 = 8.6%
Short fuel trim 2 = -0.8%
Long fuel trim 2 = 7.8%
Maf lb/min =2.548
Spark advance = 28
Rpm =2269
Speed =62 mph
Keep in mind the o2 sensors have not been changed and the disa is original .
giovannijones is offline   Reply With Quote
Old 12-07-2016, 09:38 AM   #2
markusmarkus
My Ride: 2001 330Ci
The first 2 codes indicate issues with the cats. The other code comes back as having to do with "baro"?
What's the maintenance history of the car? How has it been driven, mainly city miles? The pre-cat O2 sensors should be replaced. They're good for about 100k miles.
Old 12-07-2016, 10:46 AM   #3
giovannijones
My History of Mantanience
12/21/2005
31,806 mi
BMW of San Francisco
Maintenance inspection completed
Recommended maintenance performed
Door locks checked
Left door lock replaced
Tire(s) balanced
Tire(s) replaced
Two tires balanced
Two tires mounted
Two tires replaced
Window(s) checked
Wiper(s) replaced
11/09/2006
48,380 mi
Brake fluid flushed/changed
Oil and filter changed
Wiper(s) replaced
08/15/2007
63,435 mi
Antifreeze/coolant flushed/changed
Drive belts checked
Shift linkage checked
08/13/2008
81,080 mi
Swiss Garage
Exhaust repaired
10/22/2008
85,265 mi
Swiss Garage
Battery/charging system checked
Brakes checked
Drivability/performance checked
Exterior lights checked
Fluids checked
Lights checked
Maintenance reminder reset
Starter replaced
Steering/suspension checked
Tire condition and pressure checked
07/01/2009
97,958 mi
Swiss Garage
Brakes checked
Brakes serviced
Fluids checked
Lights checked
Parking brake adjusted
Spark plug(s) replaced
Transmission filter replaced
Transmission fluid flushed
10/26/2009
103,075 mi
Swiss Garage
Brakes checked
Fluids checked
Lights checked
Thermostat replaced
Water pump replaced
08/04/2010
106,209 mi
Swiss Garage
Cabin air filter replaced/cleaned
Fluids checked
Lights checked
Lower radiator hose replaced
Tires rotated
Upper radiator hose replaced
01/20/2011
107,908 mi
Swiss Garage
Drive belt(s) replaced
12/28/2011
Swiss Garage
Wipers/washers repaired
01/19/2012
Swiss Garage
Wheel bearing(s)/hub(s) replaced
SEE DETAILS
04/09/2013
108,241 mi
Swiss Garage
Brake fluid checked
Brakes checked
Brakes serviced
Fluids checked
Lights checked
Valve cover gasket(s) replaced
SEE DETAILS
08/14/2013
108,982 mi
Service Facility
Brakes checked
Driveshaft flex disc replaced
Fluids checked
Lights checked
09/22/2016
111,762 mi
Precision Tune Auto Care
Vehicle serviced
Replaced Fuel Filter
Cleaned MAF Sensor
check engine light, e46, p0420, p0430, rough idle
