Old 12-13-2016, 03:44 PM   #1
Archbid
My Ride: 2003 330cic
RealOEM versus my car - power steering reservoir labeling
So my current PW reservoir says "ATF". However, I am refreshing the steering lines and the replacement reservoir says "CHF11".
I was tempted to return it, but I had ordered it specifically off the RealOEM part list, and when you look at the list, it says "CHF11, S" in the specification.
http://www.realoem.com/bmw/enUS/show...diagId=32_0957
Since all the lines will be replaced, I am not sure it matters, but does anyone see an issue here?
Archbid is offline   Reply With Quote
Old 12-13-2016, 04:33 PM   #2
pack horse
My Ride: 325i coupe
CHF 11 is for self levelling suspension but as long as you use ATF you should be Ok.
pack horse is offline   Reply With Quote
Old 12-13-2016, 04:38 PM   #3
generalvp
My Ride: 05 330ci
Pentosin CHF11 is the correct fluid for your power steering.
https://www.oembimmerparts.com/CHF-1...0429576e46.htm
https://www.ecstuning.com/b-pentosin.../chf11s~smgkt/
https://www.fcpeuro.com/products/hyd...chf11s-1-liter
If you look closely at the bottom of the pic, it says "power steering".
generalvp is offline   Reply With Quote
Old 12-13-2016, 04:40 PM   #4
Dude8383
My Ride: 91 332iS, 02 325i
If it originally had ATF in it I'd keep the ATF in there. The fluids shouldn't be mixed... If you wanted to switch to CHF 11s you'd have to flush out the whole system.
Dude8383 is offline   Reply With Quote
Old 12-13-2016, 04:43 PM   #5
generalvp
My Ride: 05 330ci
Good point. when I did mine, I flushed out the old ATF fluid and pour in the pentosin until it drains the new clear pentosin fluid only.
Old 12-13-2016, 06:20 PM   #6
Archbid
Thanks!
Old 12-13-2016, 06:28 PM   #7
lingon300k
My Ride: 2005 325xi Automatic
Some of the new reservoirs say CHF11. CHF11 is a specific kind of "central hydraulic fluid."
The power steering system uses regular ATF, regardless of what the new reservoir cap says. I think they all use Dexron.
lingon300k is offline   Reply With Quote
Old 12-13-2016, 07:08 PM   #8
Megalocnus
My Ride: 05 330i ZHP/MT
I bought an OEM PS reservoir, so it came with "ZF" inscription on the lid, not "ATF oil only" as on the original one.
Ended up using the old lid with a new Viton O-ring on the new reservoir.
Megalocnus is online now   Reply With Quote
Old 12-13-2016, 09:05 PM   #9
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
^This. Re-use the old cap so it doesn't confuse future refillers, but use the o-ring off the new cap, or a nice new Viton one.
///Mmmmmm...
Old 12-14-2016, 01:13 PM   #10
RJLynn
My Ride: '01 330Ci 'vert
When I got a new cap at the dealer, it said CHF11 as well, but had a sticker to be applied over top that said ATF only. So there's that.
RJLynn is offline   Reply With Quote
Old 12-14-2016, 01:17 PM   #11
Archbid
Going to use the old cap!
chf-11, power steering
