Old 12-20-2016, 01:16 PM   #1
rako92
My Ride: E46 318i M43
LTFT, MAF and Cylinders - does this look right?
Hi guys.
I replaced my MAF sensor today. The reasons: it was showing fault 120 in INPA, poor RPM at idle, my cruise control was switching itself off, all there may be because of bad MAF.
So I purchased a second hand one and connected it to the car (BMW E46 318i M43 2000). Is there some coding that I need to do? After I connected the new MAF and clearing the fault codes in INPA, no more faults show up. However, I'm not sure there is a big change in the RPM in idle, the cruise control still switches itself off after some driving (a couple of hundred meters...).
Then I started INPA to see the readings.
The values:
What bothers me - the rough values, seems that they are all a total mess: Cyl 1 is too low, Cyl 3 is 0.00, 2 and 4 are too high I believe?
The other bothering value - the Mg/As/Zyl is far above the norms, as you can see in the pics.
Using another, bluetooth OBD2 scanner, I got data that the Long term fuel % trim Bank 1 is -0.8 and the MAF air flow rate is 2g/s, all in idle.
I believe these values are a mess, but can't find a proper data saying what are the 'normal' values. What should the Air Mass be in idle and what is this Mg/As/Zyl? The only results I got are in Polish forums..
Thanks dudes
rako92 is offline   Reply With Quote
cruise, e46, m43, maf
