E46 Xi Forum
Old 12-27-2016, 04:54 PM   #1
k.kask
My Ride: Bmw 330xd e46
330 xd hum/ vibration
Hello, problem with 330 xd e46 2003, 5 speed manual
Car is humming/ slightly vibrating from rear of car, sounds like under the rear seat, it also does thump sound when changing any gear( that seems to come from trasfer case or around it).
Humming is the worst with 4 th gear , accelerating 40- 55 mph and then disappears entirely. 3 rd gear makes that noise accelerating 2200-2500 rpm, only for a second. 5 th gear same speed 40-55 mph, but humming is not so bad as with 4th gear.
Checked central shaft bearing, looked fine and tight, same for the guibo/ flex disc, but there was a play in differential side u- joint, is it possible cause of my problem? Also, the transfer case front output shaft bearings are worn, but i doubt that those two are making that weird humming sound.
Any ideas?
k.kask is offline   Reply With Quote
330xd, driveshaft, humming, vibration, xd
