E46 Xi Forum
Old 01-04-2017, 08:06 PM   #1
Gunner_e46
My Ride: 2001 e46 325xi
Car not moving when put into any gear
Hi I am new to this forum and I am in need of some help. I have a 2001 325xi 5 speed manual. I was driving my car today and it started making this grinding and clanking sound right by the passenger front door. I turned a corner and all of a sudden my car started shaking like the front right tire was loose and it made a terrible clunk. As I turned the corner I downshifted into second and all of a sudden I can't drive anywhere and the clutch seems to be fine. When put in to gear and try to take off it just clunks under the passenger side front. If anyone has any information that would help me I would gladly appreciate it THANKS!!!
Gunner_e46 is offline   Reply With Quote
Old 01-04-2017, 08:09 PM   #2
shiftyshadow17
My Ride: 2003 325xi
It would have to be something with the drivetrain, like the transmission/front differential/ or transfer case, you said the clutch is fine?
shiftyshadow17 is offline   Reply With Quote
Old 01-04-2017, 08:10 PM   #3
bmwbob89
My Ride: M-5 325 X3 528 740
Sounds like you lost a front axle. Turn the wheel and look in there with a flashlight. Should be obvious.
bmwbob89 is offline   Reply With Quote
Old 01-04-2017, 08:11 PM   #4
shiftyshadow17
My Ride: 2003 325xi
Thought about that also but wouldn't you still be able to move or no?
Old 01-04-2017, 08:33 PM   #5
Gunner_e46
If I would lost a front axle wouldn't my car still be able to drive?
Old 01-04-2017, 08:36 PM   #6
Gunner_e46
Yes the clutch is fine I don't think it's the transfer case I believe that only send power to the front wheels. Are there any input shafts that are likely to bust?
Old 01-04-2017, 08:46 PM   #7
Gunner_e46
It almost seemed like something was out off balance in the transmission or somewhere along the drivetrain
Old 01-04-2017, 08:56 PM   #8
shiftyshadow17
My Ride: 2003 325xi
How can you tell the clutch is fine? A broken front axle shouldn't prevent the car from moving. You can't roll it or anything?
Old 01-04-2017, 09:04 PM   #9
LD330XI
My Ride: '09 335i
A broken front axle will prevent the car from moving under its own power. The drivetrain on e46 Xi's is open.
Sounds like a front axle to me.
LD330XI is offline   Reply With Quote
Old 01-04-2017, 09:05 PM   #10
shiftyshadow17
My Ride: 2003 325xi
Never knew that, thank you for correcting me. I'm still learning, this is my first car also, so since the axle is broken it can't move? any reason for that, or is it just because the car has open diffs?
Old 01-04-2017, 09:11 PM   #11
Gunner_e46
Yes the car is able to be pushed we had to push it 3 blocks back to my buddies house and when being pushed the car didn't make any weird noises only when put into gear and I let the clutch out
Old 01-04-2017, 09:14 PM   #12
Gunner_e46
So check the front axle and Tha may be the problem?
Old 01-04-2017, 09:37 PM   #13
shiftyshadow17
My Ride: 2003 325xi
Yes check it
Old 01-13-2017, 09:08 PM   #14
WilloCO
My Ride: '05 330xi 6 speed
Check all the axles, diffs and driveshaft. Should be easy to find the root cause if you have a jack and a friend handy.
WilloCO is offline   Reply With Quote
Old 01-13-2017, 10:26 PM   #15
jmo69
My Ride: 03 325xi 98 328is
If an axle pulls out of the dif just a little the car will not move, that's why the axles have to be driven all the way in when changing them. This has been discussed before on this forum.
HERSHIS
2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 01-14-2017, 09:41 PM   #16
gordo325xiwagon
My Ride: 01 325xit '12 328i
No, if the front axle is broken, or the splined shaft broke a clip and slip out of the front diff, the car will not move. We don't have locker diffs.
____________________________________________________________ _____________
2001 325xit and 2012 328i Sportwagon
gordo325xiwagon is offline   Reply With Quote
Old 01-14-2017, 10:18 PM   #17
Gunner_e46
Car is already fixed and it was the front driveshaft that busted
Sent from my SM-G900R7 using E46Fanatics mobile app
drive axles, drivetrain, transmision failure, transmission, Îi
