Rear Passanger Door Water Leak! HELP! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-23-2017, 04:52 AM   #1
DMartBossman
My Ride: 2003 E46 330i
Since this LA rain has been happening, I started to notice that my rear passenger side carpet was moist with water. I got the chance to investigate while it was raining and tried to track it down. To my surprise, after removing the cover molding near the bottom of the seat I notice that water was leaking in near the inner door seal.
Has anyone had this problem? Is there a fix to this? Not really planning on paying $95 for a new inner seal.
ID:	649225   Click image for larger version
ID:	649226   Click image for larger version
DMartBossman is offline   Reply With Quote
Old 01-23-2017, 05:00 AM   #2
steviehp1
My Ride: 3 series E46 2003
Your door seal looks dry and cracked, rub your seal generously with linseed oil or vase line to restore its flexibility, it helped mine after a few attempts.
The Pipster has spoken
steviehp1 is offline   Reply With Quote
Old 01-23-2017, 07:58 AM   #3
markusmarkus
My Ride: 2001 330Ci
OP, has the door card (the interior cover) ever been removed? There's a vapor barrier behind the door card. It may have been removed and improperly replaced. That'll cause leaks. Also, check the drain holes on the underside of the door. They could be clogged.
Old 01-23-2017, 04:05 PM   #4
DMartBossman
I did get my speakers change a while back.
Today I got the chance to remove my rear panel and the vapor barrier was seal properly and it was completely dry.
After putting back the rear panel on, I just lifted the inner sealed up and here's what I saw.
Does this mean I should might as well buy a new inner sealed?
Old 01-24-2017, 07:57 AM   #5
markusmarkus
My Ride: 2001 330Ci
Hmmmm. That foam cover may or may not be the vapor barrier!! That looks like a sound deadening layer. The vapor barrier is usually a fairly thick plastic sheet (thickness: at least 15 mil) that's attached to the door with some nasty black tar-like substance. As far as the gasket, it depends on where the broken section is located. If it's at the bottom I'd leave it perhaps with a bit of repair using RTV. These gasket are very expensive, btw.
Old 01-24-2017, 09:13 AM   #6
jeepo23
My Ride: 2008 X3, 6 Speed
What you have there is a vapour barrier. The vapour barrier may look fine. But did you run your fingers around the edge of it where its glued/sealed to the door. I'm betting that its not fastened all the way around your door as it my appear. Run your finger around it and see if you can pop it through anywhere
** Removed **
jeepo23 is offline   Reply With Quote
Old 05-06-2017, 07:12 PM   #7
ValkyrieSDF1
My Ride: 2004 325xi
Hey I just developed this exact same problem on the exact same door in April of 2017. Any luck fixing it so far?
ValkyrieSDF1 is offline   Reply With Quote
Old 05-06-2017, 07:20 PM   #8
DMartBossman
Yes! After all it was the vapor barrier; i stopped by petboys to buy a small sealent and I reglued the spots that were pealing off and No more leaks.
Old 05-06-2017, 09:24 PM   #9
ValkyrieSDF1
My Ride: 2004 325xi
Wow, ok, thanks. That must be my problem.
My drain holes are clear. None of my seals seem brittle or damaged.
But what is sad is that I just replaced the window regulator on this door. The leak had started BEFORE that. I didn't think anything was wrong with my moisture barrier when I did that project. But maybe I need to "glue" it on better.
Congrats on fixing yours.
e46, inner seal, rear door, water leak, water problem
