Sponsored by The Tire Rack
Old 01-26-2017, 08:09 PM   #1
JLB1977
My Ride: 2002 330ci
Powder Coating Rims
I just bought a 2002 330ci with newer Michelin tires so I don't want to replace them right now. I was thinking about having the rims powder coated instead of getting new rims.
any pros and cons to powder coated rims?
JLB1977 is offline   Reply With Quote
Old 01-26-2017, 08:44 PM   #2
bach6177
My Ride: 2010 n63 X6
Really no cons to powdercoat. Strongest finish for your rims.
bach6177 is offline   Reply With Quote
Old 01-26-2017, 09:00 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
You want your wheels restored properly, these are the guys you want to use - http://www.princewheelservices.com/
These guys are the real deal, not the curb rash mobile guys that charge you $125 for a 2 hour touch up.
They fully restore each wheel, can mount and road force balance tires if needed.
Check each wheel for straightness
For a small extra charge properly straighten the wheel(s)
They will 100% media blast the wheels
Rinse in a phosphate bath
Oven dry the wheels
Prime wheels to include the inner barrel, oven bake?? Not 100% sure if this is done for typical powder coat process????
Color powder coat the wheel, oven bake
Clear coat wheel, I believe powder coat, oven bake
If you need or choose Shadow Chrome finish these guys are only a handful of shops that can do this properly
Old 01-27-2017, 12:47 PM   #4
asianisafish
My Ride: 330ci
powder coat is the way to go.
find a place that offers lifetime warranty on it aswell.
dont forget if you have multi-piece wheels, they might be a labor charge for the disassembly and reassembly-but you can also play with color combos with hardware, barrels, faces, lips, lugs bolts/studs etc
asianisafish is offline   Reply With Quote
Old 01-27-2017, 01:22 PM   #5
Spannerhead
Save the Manuals!
Spannerhead's Avatar
My Ride: '02 330i/5 slicktop
What color?
Current: '02 330i/5 '10 Mazda5 '72 240Z
Past: '85 GSL-SE '95 540i/6 '95 525i/5 '86 635CSi/5 '88 JZA70 '86 4K quattro '85 RX-7 S
Spannerhead is offline   Reply With Quote
Old 01-27-2017, 04:25 PM   #6
Alex323Ci
My Ride: M3 & 323Ci (sold)
power coating is the best of the bunch. it also usually fills in minor scratches. prices vary per regions.
cons: higher cost, can cover-up some fine details in a wheel's design.
Old 01-27-2017, 05:18 PM   #7
das_autobahn
My Ride: 2004 330ci coupe
id powdercoat. durable and lasts life of rim. if it needs redone just sandblast and powdercoat again. i had motorcycle rims done and they turned out awesome!
das_autobahn is offline   Reply With Quote
Old 01-27-2017, 06:36 PM   #8
JLB1977
My Ride: 2002 330ci
thanks
thanks for all the input- Im gonna go with whatever grey color is closest to brake dust-
Old 01-28-2017, 10:52 PM   #9
Knight
My Ride: '05 330Ci | '01 325i
Find a reputable shop and go for it. I had a set of Style 68s powder coated. Cost $400 to refinish and mount/balance new tires. The results speak for themselves and l will be having another set refinished soon.
-Sent via E46Fanatics mobile app.
Knight is offline   Reply With Quote
Old 01-29-2017, 10:28 AM   #10
bach6177
Not sure where your located but I charge $400 for a set of 4. Includes mount and balance
Old 01-29-2017, 01:48 PM   #11
Knight
That set was done at Static Coatings in Clifton, NJ. Tom is very knowledgeable and his work is top notch.
www.staticcoatings.com
powder coat, rims
