Old 01-28-2017, 02:28 PM   #1
Nkzhendi
My Ride: 2001 325i
Car wont start, cant figure it out.
My 01 325I has an issue starting sometimes. I will turn the key over to start the vehicle and it makes a weird vacuum noise when it should be turning over. It will do it once or twice and then it will start fine. Just recently I was driving and my car downshifted kind of hard then my dsc triangle light and brake light turned on. Car stalled and I couldn't get it to start, it just makes that same vacumn noise as I spoke of earlier. I let it sit over night and it starts fine the next day. I haven't found any threads on this so thought I'd give this a shot! I have no clue what it could be? Throttle body? Throttle position sensor? Thanks in advance!
Nkzhendi is offline   Reply With Quote
Old 01-28-2017, 02:36 PM   #2
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
My Ride: Project 330xi
Sounds like a bad fuel pump to me. They are known to have this erratic, intermittent behavior when they're on their way out. Do a little reading around here on fuel pumps and see if it matches your symptoms.
Are any codes being thrown?
-Gary
DiscoStu is offline   Reply With Quote
Old 01-28-2017, 02:39 PM   #3
Nkzhendi
My Ride: 2001 325i
Thanks disco stu, and I haven't had the chance to get the codes read. Will do it tomorrow if not tonight. Would the fuel pump cause the Dsc triangle and brake light to be illuminated?
Old 01-28-2017, 02:42 PM   #4
DiscoStu
Sienna Red Coupe
DiscoStu's Avatar
It was likely caused by the stall of the engine. If you were under load and the fuel pump cut out instantly, it might cause the engine/transmission to lurch like that. Just my guess, so take it with a grain of salt. I still think it sounds like a bad fuel pump though.
-Gary
Old 01-28-2017, 04:31 PM   #5
delgadilloalex
My Ride: 2001 325Ci
Check your fuses for fuel pump. Also is it cranking?
Sent from my SM-N900T using E46Fanatics mobile app
delgadilloalex is offline   Reply With Quote
Old 01-28-2017, 04:37 PM   #6
Nkzhendi
My Ride: 2001 325i
Thanks for the reply delga. Okay I will check the fuses, and that's the thing it doesn't crank it makes a weird vacuum-ish noise coming from the engine area. It doesn't do the clicking like it normally would if it were a battery issue, etc. It just makes that unusual vacuum noise.
Old 01-28-2017, 05:11 PM   #7
delgadilloalex
My Ride: 2001 325Ci
First the noise you're hearing is the fuel pump priming. It makes a sound that last 1 second when you put the key in possession 2. If it's not cranking it might be the starter.
Old 01-28-2017, 05:13 PM   #8
delgadilloalex
My Ride: 2001 325Ci
I've never tried it on bmw's. But I used to hit the the starter with a heavy stick or pipe while someone cranks the key and it might start.
Old 01-28-2017, 07:20 PM   #9
Nicker
My Ride: 323ci
used to work with my ex-gf's hatchback mustang. what a pain in the ass.
I believe its rattling/cleaning the brushes on the motor, since they only have finite use.
00' 323ci - 170hp
Nicker is offline   Reply With Quote
Old 01-28-2017, 08:04 PM   #10
bmwbob89
My Ride: M-5 325 X3 528 740
The vacuumish noise might be the secondary air pump motor running. See if that is what your hearing its out by the windshield washer tank. Then you have to figure out if its a starter problem or maybe a key issue. Try another key.
bmwbob89 is offline   Reply With Quote
Old 01-28-2017, 11:58 PM   #11
randy72877
My Ride: 01 330 sport 5m sil/
Sounds like the starter motor is working but sometimes the gear doesn't engage with the flywheel or flexplate. A free spinning starter sounds similar to a vacuum cleaner. You need to read codes from the vehicle. I would recommend using a bmw specific diagnostic program or scanner with the capability to diagnose the entire car. Your problem affects multiple systems. Starter problem is separate issue. If you do have obd 2 generic scanner only it would be a good start.
Sent from my SAMSUNG-SM-G870A using Tapatalk
randy72877 is offline   Reply With Quote
battery, no start, throttle body
