This 330i/Transmission swap worth it? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-30-2017, 02:36 PM   #1
Beamschemin'
My Ride: Cadillac CTS
Hi guys,
I'm new to the forum and I came because I wanted some opinions and advice on this. I work at a carmax and I could get a wholesale 2001 BMW 330i with about 111k miles for about $800, but based on the warning lights lit up it may need a new transmission and some work done to the break system. Seems to run fine other than being in limp mode due to the tranny. It's an automatic so ultimately I would want to swap it to a manual anyway. Would the money/work be worth it? (I have some mechanical knowledge and experience but nothing this serious). Thanks. Will include pictures if someone tells me how lol
Beamschemin' is offline   Reply With Quote
Old 01-30-2017, 02:44 PM   #2
SiVaE46
My Ride: 2003 325i
There are plenty of threads here talking about manual swaps - if you manage to diy then cost could be reasonable. You can find used auto at junk yard for $200 - no warranty - specialist will charge you $1-$2k to install - so again maybe only worth it if you think you can do the job yourself - I think this is hard without access to a lift ...
SiVaE46 is offline   Reply With Quote
Old 01-30-2017, 02:46 PM   #3
cvx5832
My Ride: 325Ci, 325Cic, C300
It's already worth more that in parts. If you're willing to do the work then there's a guide to get you through it. You might even get lucky if the transmission and brake issues turned out to be simple fixes as they sometimes are.
cvx5832 is offline   Reply With Quote
Old 01-30-2017, 05:54 PM   #4
YoitsTmac
My Ride: 328Ci
I'd do it if I were you, but I really want to do the same lol. If you ever wholesale a 6 speed let me know!
TM
YoitsTmac is offline   Reply With Quote
Old 01-31-2017, 07:42 AM   #5
Beamschemin'
Thanks for your input so far
I think I'll have the safety inspection done and see what comes back. Seems like it could be a lot of different things that cause the transmission light and limp mode. I will update you with my results.
Old 01-31-2017, 09:11 AM   #6
markusmarkus
My Ride: 2001 330Ci
You need to read the codes from the tranny control unit. It could be something very easy to fix. Or, it could need a new tranny!
Old 01-31-2017, 09:38 AM   #7
Beamschemin'
I'm hoping the safety inspection I have to get done will reveal something
Old 01-31-2017, 03:57 PM   #8
Beamschemin'
So apparently for some reason in two independent searches the vin shows a manual trans. Carmax showed a 7 speed and my grandpa's google search showed a 5 speed.
Old 01-31-2017, 04:17 PM   #9
CylonRed
My Ride: '01 E46 330i sport
Was the vin search on RealOEM?
CylonRed is offline   Reply With Quote
Old 01-31-2017, 04:23 PM   #10
WDE46
My Ride: '13 128i, '04 330Ci
Probably best not to rely on old people google-fu. It's sub par. It should say MECH in the transmission listing. It won't say number of speeds. You just have to know that 2001 330s came with a 5 speed.
This has been working well for me.
http://bimmer.work/
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 02-08-2017, 04:42 PM   #11
Beamschemin'
I'm not sure if it was realOEM or not.
I just got the results back from the safety inspection. Didn't do too bad. The issues found are as follows:
Leaking shock needs to be replaced,
A couple away bar end links need replacing,
Windshield washer motor inop,
Rack boots torn,
Diff bushings need replacing,
And of course it's in limp mode which I already knew about.
Didn't give me any of the codes so I guess I will have to read those myself.
I think I've decided to buy it and do further diag myself. Worst case I'll just part it out as mentioned. I want to swap the trans (which I believe to be the issue) anyway so I don't think I can come out losing at just under 1k out the door.
Old 02-08-2017, 04:48 PM   #12
Beamschemin'
http://imgur.com/a/6xNzY
Here is some pictures of the car.
Old 02-08-2017, 04:52 PM   #13
Beamschemin'
http://bimmer.work/
I just used that site and it shows it has the auto option
330i, advice, cheap, transmission swap
