Old 02-07-2017, 01:29 PM   #1
Markvv
My Ride: 320i sedan
BMW E46 320i starts bad
Hello everyone,
I am from the Netherlands so excuse me for my bad English.
I own a BMW e46 320i from 2001, it starts very bad.
When i turn the key the starter turns and engages with the engine but won't fire up because it gets no fuel.
When i turn the key but won't start the car i don't hear the pump priming, when I do this a few times the pump primes and when I fire up the car after that the engine starts immediately en runs good.
When I "started the car" but it failed I pulled off the connector to the pump and measured around 12 vdc.
I have replaced the fuel pump relay, the Ignition switch and the fuel pump.
Does anyone knows what could be wrong?
Mark
Markvv is offline   Reply With Quote
Old 02-08-2017, 09:15 AM   #2
markusmarkus
My Ride: 2001 330Ci
You need to have the engine computer scanned for codes. The computer can have codes with the SES/CEL being on. That's always the first step in diagnosing a problem in a modern car.
U moet de motor computer gescand op codes. De computer kan codes met de SES / CEL wezen op hebben. Dat is altijd de eerste stap in de diagnose van een probleem in een moderne auto.
markusmarkus is online now   Reply With Quote
Old 02-08-2017, 10:15 AM   #3
Markvv
My Ride: 320i sedan
The dealer has checked the car for codes, there were no fault codes. I have purchased a bmw scanner 1.4.0. And with this scanner I also cannot find any fault codes about this error.
fuel pump
