Old 03-21-2017, 01:59 PM   #1
JAMESphysique
My Ride: 325i 2001
E46 Bad MAF. Clean it or Replace ?
Found out I have a bad MAF. Should I replace or clean? I don't know if it usually starts to work if you clean it..
JAMESphysique is offline   Reply With Quote
Old 03-21-2017, 02:02 PM   #2
M_3_X
My Ride: E46M, 330Xi, E30, X3
If it's bad, I'd just replace it.
2002 ///M3 Coupe, Steel Gray, black leather, HK, 6MT.(01/2015-current)
2005 X3 3.0i ZPP, Htd seats, Htd strng whl, Black Sapphire on Terracotta.(08/2008-current)
1991 325i Convertible, 5MT, htd seats
2004 330Xi Orient Blue, 6MT, Sport, Premium - Son
1995 ///M3 Coupe, Luxury, MT, Htd seats, Cosmos Black.(11/2011-01/2015)
2003 325Cic Orient Blue, Premium (03/2007- 03/2010)
River City Bimmers - BMW CCA Chapter
M_3_X is offline   Reply With Quote
Old 03-21-2017, 03:09 PM   #3
mtnbimmer
My Ride: 325xi
If it's bad what good would cleaning do?
mtnbimmer is offline   Reply With Quote
Old 03-21-2017, 03:46 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
How do you know it is bad? An Asian counterfeit MAF is always bad!!
I rarely see a totally failed MAF, most are degraded and under report due to aging.
What problem(s) are you trying to solve?
Cleaning a MAF is pretty much a waste of time and money.
Old 03-21-2017, 03:48 PM   #5
DEADF15H
My Ride: 2001 325i Auto
How do you know it's the MAF? Codes?
Plenty of misdiagnosed MAFs, as it's easy to confuse it with a vaccum leak.
Especially if the technician isn't bmw specialist.
They sell a lot of MAF cleaner, it's cheap, rarely successful, but worth a shot.
Sent from my flame proof Samsung Note 4
DEADF15H is offline   Reply With Quote
Old 03-21-2017, 04:46 PM   #6
05SMG
My Ride: 2005 330ci ZSP
An 01 that's pretty old. Replace the MAF. FCP oem cost me $230 ish. Literally solved everything. LTFT are at zero and no cold start stumbling.
Technically 05SSG
05SMG is offline   Reply With Quote
Old 03-21-2017, 04:50 PM   #7
Schlag96
Slightly Modded ///Member
Schlag96's Avatar
My Ride: 1999 323i
was that the siemens/VDO? Who makes the genuine BMW one? any idea?
Schlag96 is offline   Reply With Quote
Old 03-21-2017, 05:26 PM   #8
OnTheFence
My Ride: 2001 330i (and 530i)
Seimens/VDO at FCPEuro with price match is like $140.
Do a search
OnTheFence is online now   Reply With Quote
Old 03-21-2017, 07:44 PM   #9
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Unless you drove over it or otherwise trashed it, I suspect it may be fine, but "other information" makes you think the MAF is the culprit.
Sooooooo, why do ya think it's bad?
///Mmmmmm...
Old 03-31-2017, 05:21 PM   #10
JAMESphysique
My Ride: 325i 2001
When on cold start its disconnected it idles perfectly, but when I reconnect it, it rough idles hard AF and sometimes turns off.
Old 03-31-2017, 05:28 PM   #11
jfoj
Leave the MAF alone, read this at least 3 times: Solve your misfires, lean codes, rough idle - http://forum.e46fanatics.com/showthread.php?t=897616
Old 03-31-2017, 05:32 PM   #12
All2kool
My Ride: 2002 325Ci
...disconnected it idles perfectly, but when I reconnect it, it rough idles hard AF and sometimes turns off.
This is the very logic and troubleshooting we (5 years Tech Support for me) used in diagnosing computer issues. If it doesn't work when it's plugged in and it does work when it's not plugged in, you have generally found out what is not working correctly.
All2kool is offline   Reply With Quote
Old 03-31-2017, 05:47 PM   #13
jfoj
This is not the case with Engine Fuel Management systems.
Unplugging the MAF will cause most DME/ECU/ECM to fall back to a default fuel delivery MAP that is Richer than when the MAF is connected. What this typically does is MASK Lean problems due to vacuum leaks. Most engines default to a Richer mixture to keep the combustion chamber temperatures lower to protect the engine from damaging detonation.
But you guys decided what you want to do.
Keep in mind you are a FOOL to buy a used MAF, a cheap MAF from ebay or a $50 MAF from the local auto parts store. There are also A LOT of Asian counterfeit MAF's that are often sold for in the $50-$75 range and some are even sold at the same price as name brand parts and will often be in name brand boxed, have official looking stickers and logos cast in the housing. These will cause you all sorts of headaches.
The MAF is the single most sensitive and important sensor on the engine for determining fuel delivery. Measuring the weight/density of air is not a simple and easy task.
Old 03-31-2017, 05:50 PM   #14
JAMESphysique
My Ride: 325i 2001
Thanks for all the advice everyone ! I deff won't buy cheap eBay junk. Quick question, will 2003 CI struts, control arms, links fit 325i 01 ? thank you for any advice
Old 03-31-2017, 05:57 PM   #15
jfoj
No convincing evidence the MAF is bad and needs to be replaced at this point.
Old 03-31-2017, 06:33 PM   #16
JAMESphysique
My Ride: 325i 2001
lol. Its old but getting it for 500 with 120 something thousand miles is a steal. Plus, making it a project.
bad maf, bmw, maf, maf cleaner
