///M3 Forum
Old 03-26-2017, 06:16 PM   #1
1marvin
My Ride: E46 m3
Smg pos problems
I recently bought a e46 m3 convertible the problem i was having was it is not able to shift manually and auto shift kinda worked with a selection of only 2nd 5th and 6th gear or reverse I had the computer reset and smg codes read only code that came up was 2 internal faults
I go to bring it back to the shop stalls out while I'm doing about 10mph then dosent want to start so I leave it then it finally starts after an hour of sitting but now when you put it in gear it flashes zero and either stalls and jolts the car foward or if you press the gas it will move then slip out of gear than catch while still flashing zero if put it reverse it just grinds and stalls and jerks the car
I have also had the yellow cog the whole time
1marvin is offline   Reply With Quote
Old 03-26-2017, 07:10 PM   #2
Antonio13
My Ride: 05 BMW e46 m3
There isn't many parts that will make this happen and the only one I think that can do stuff like this is your smg pump, it's most likely on its way out. Your best bet is just getting a new one or used but be carefull with those.
Sent from my SM-G925V using E46Fanatics mobile app
Antonio13 is offline   Reply With Quote
Old 03-26-2017, 07:13 PM   #3
1marvin
My Ride: E46 m3
Won't the car cause no start issues with a bad pump I'm no longer having the no start issue it will start and idle but not move
Old 03-26-2017, 07:38 PM   #4
Antonio13
I can't really tell you about that, mine had issues like this and when I'm driving from time to time it would go into neutral and won't go anywhere with the gears. If you want to go cheaper route you can change the salmon relay on the pump, they are like 20$ and it won't hurt if you do it, but I can't guarantee it will fix your problem.
Old 03-28-2017, 03:37 PM   #5
1marvin
My Ride: E46 m3
I replaced the relay still just flashes zero and when i press the gas pedal feels like the clutch is being pushed in and out then stalls reverse just grinds
Old 03-28-2017, 05:18 PM   #6
Alan
Alan's Avatar
My Ride: 2006 M3
You should talk to whoever did your PPI.
Alan is offline   Reply With Quote
Old 03-28-2017, 05:45 PM   #7
1marvin
My Ride: E46 m3
I didn't have one done
Old 03-28-2017, 05:56 PM   #8
Alan
Alan's Avatar
My Ride: 2006 M3
And so it goes...
At least you saved $200.
Old 03-28-2017, 08:56 PM   #9
Imola46
My Ride: Porsche, BMW, Merced
You obviously knew about potential SMG issues before buying the car so you should be fine.
Imola46 is offline   Reply With Quote
Old 03-30-2017, 10:15 AM   #10
968951M3
My Ride: E46 M3 Cab
Check the compression springs, I believe there are 2.
Current
03 E46 M3 Cab Carbon Black/Black
Recent Past:
95 E34 540/6 Black/Black
95 E36 M3 Cosmos Black/Black
89 E24 Black/Black
89 E30ix Diamond Black/Tan
95 E34 Touring Black/Black
86 951 Black/Black
94 968 Polar Silver/Black
968951M3 is offline   Reply With Quote
Old 04-01-2017, 11:55 PM   #11
Commando
My Ride: '02 325Ci MT '04 M3
This is a bit like trying to repair a laptop by listening to the POST beeps and watchin the HDD light but not opening the screen.
How long was it working properly?
What were the internal faults?
What are the codes now? The cog light won't come on if there are no codes.
Commando is offline   Reply With Quote
Old 04-02-2017, 08:34 PM   #12
albelopez
My Ride: 2004 e46 m3 6mt
I have my old bmw e46 m3 smg pump for sale if you need it. I can give you a 10k mile warranty on the part since it is used. It was tested before it was removed (swap to manual) and built the right pressure. Feel free to PM me. Best of luck!
albelopez is offline   Reply With Quote
Old 04-03-2017, 01:32 AM   #13
Commando
Ok get codes - see whats happening. Hydraulic pump assemblies can be repaired for much less than the complete replacement price. Other items can cause these issues so look before you leap.
Old 04-03-2017, 04:43 PM   #14
Richard Vincent
My Ride: BMW 330ci
I have a song tyranny myself and it just jerk around in fist gear it doesn't start moving until the rpm reach 3000 then slams in and stalls the car... Any suggestions
Richard Vincent is offline   Reply With Quote
Old 04-03-2017, 04:44 PM   #15
Richard Vincent
My Ride: BMW 330ci
Sorry I meant smg
Old 04-03-2017, 08:43 PM   #16
Commando
Once again is it showing any codes?
Is it the same in reverse? How about a 2nd gear take off?
When was the last time you did the gearbox/clutch adaptations?
Old 04-24-2017, 06:21 AM   #17
1marvin
My Ride: E46 m3
Update car drives but only shifts at high rpm automatically and only has 2nd 5th and 6th oe just blinks 0
Old 04-24-2017, 08:38 AM   #18
Commando
Have you run any diagnostics at all or is this going to be entirely guesswork?
Old 04-25-2017, 10:51 AM   #19
968951M3
My Ride: E46 M3 Cab
Still haven't pulled fault codes? Good Luck...
Current
Recent Past:
89 E24 Black/Black
86 951 Black/Black
Old 04-27-2017, 03:15 PM   #20
1marvin
My Ride: E46 m3
Im not sure if they will show up the cog does not go on until you start moving and is off on every start up
bmw, e46, smg failure, smg m3, smg problem
