E46 Xi Forum
Old 03-28-2017, 07:12 PM   #1
nicksdodge318
My Ride: 2004 325xi 5spd
Double shear selector rod for an xi
Well, today marks the day that I'm sick of the side to side movement in my shifter. About 4 months ago now I replaced all the linkage bushings and shifter in my 04 325xi and it had made a big difference. My problem is that my side to side slop never went away. I've had people claim to me that all xi cars have a factory dssr, but I call bull on that. Mine isn't (wish I took a picture to prove it but I didn't know at the time).
So has anyone found a dssr for our cars? I'm almost willing to hang your photo from my mirror as tribute if you help me.
nicksdodge318 is offline   Reply With Quote
Old 04-28-2017, 08:30 AM   #2
matt270avian
Banned User
My Ride: 2002 325XI
The Xi cars do not have a factory DSSR. Your model may vary, but it looks like all 5 speed Xis have the same selector rod. If you have fabrication skills you can buy the UUC Xi DSSR and modify it to fit. The reason it will not fit is because UUC will send you a straight rod instead of a bent one to match the shape of the OEM rod. The bend is critical to clear the end of the transmission as well as the transfer case. It took myself and a friend an hour or two to measure, cut, and bend a new rod to create a perfectly fitting DSSR using the factory rod as a jig. I'm a little upset that I had to drop 130 bucks on a piece of metal that I had to make fit right and it doesn't seem like UUC is willing to work with me on that...... Whatever, it fits now and I just want my car back together.
matt270avian is offline   Reply With Quote
Old 05-18-2017, 07:53 AM   #3
EvaJuli
My Ride: E46 325XiT
I need to do a bushing overhaul, but am hesitant because there is so much in the way compared to the RWD models.
What do you need to remove to get up there?
I have seen the instructions for the RWD models, but the XI is much different under there.
Does the transfer case need to be removed?
EvaJuli is offline   Reply With Quote
Old 05-18-2017, 01:21 PM   #4
matt270avian
Banned User
My Ride: 2002 325XI
The transfer case does not NEED to be removed, but it's just an extra 6 or so bolts and it gives you all the room in the world. The 2 extra minutes it takes is worth it all the way. Otherwise things are mostly the same as the rwd cars
325, dual shear, selector rod, shifter, xi
