Exhaust vibration reducing gum broken - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-06-2017, 06:03 AM   #1
space7
My Ride: E46
Hi, so i have a problem with my exhaust [E46 05 touring].. From bottom of my car I could see "thing" attached out like cable or something. Later I checked it and it seems it was from exhaust, it's "gum" which reduces vibration. Now its detached because of corrosion. I took this gum out. I don't know should i repair it or not, because exhaust has more vibration but overall it's fine. Here are photos:
http://www.part.lt/img/d1c8fb024ad12...c1101df955.jpg
http://www.part.lt/img/51f10e17fae2a...5ef5b8d673.jpg
http://www.part.lt/img/ed968c87dd3cd...538a9f7143.jpg
http://www.part.lt/img/ae860c15c03fd...a6ae261580.jpg_a_
space7 is offline   Reply With Quote
Old 04-06-2017, 12:24 PM   #2
Starvega
My Ride: 323i
The "gum" is just a rubber exhaust hanger/isolator. The metal piece is the actual hanger which is obviously broken off. You're probably feeling vibration because the exhaust is sagging and making contact somewhere else on the car. You'll have to get the hanger welded back on, or you could possibly use one of hose universal deals from the parts store if you can find a place to mount it.
Starvega is offline   Reply With Quote
Old 04-06-2017, 01:56 PM   #3
2BMW328ci
My Ride: 2000 BMW 328ci
Cylinders 6-3-2-5 all misfiring according to scanner.. replaced x2 fuel filters in less than 2wks.. originally had Bosch, changed to Micro Guard, then WIX... problem still there.. any suggestions???
Sent from my SAMSUNG-SM-J120A using Tapatalk
2BMW328ci is offline   Reply With Quote
Old 04-06-2017, 06:55 PM   #4
Starvega
My Ride: 323i
Might want to make your own thread.
Check for failed ecu though.
Old 04-06-2017, 07:24 PM   #5
2BMW328ci
I apologize
Old 04-07-2017, 03:54 AM   #6
space7
My Ride: E46
Well exhaust is not sagging and its not making contact or rattle sounds because there are 2 more holders: 1 in the front and 1 in the rear and this one broken is in the middle. So like i said overall it's fine just exhaust is making more vibration than usually which is not good in long term run..
I think i should put the rubber back on metal which is attached to exhaust and hang with some tie zippers to somewhere i think it would be good solution because zippers won't melt as it only hold rubber which is hot resistant. What do you think about it? After all if you can't fix it with zip ties, you are not using enough zip ties...
Old 04-07-2017, 08:21 AM   #7
space7
My Ride: E46
Here is the result:
http://www.part.lt/img/03c3888ae3f40...f771950263.jpg
http://www.part.lt/img/ddb3aaf01c225...df46802925.jpg
What do you think?
Old 04-07-2017, 09:01 AM   #8
jmo69
My Ride: 03 325xi 98 328is
They'll hold for a while, but I'd prefer something more permanent.
][/2003 325xi auto Stahlgrau almost modless, just lots of new parts. 1998 328is 5sp lowered, X-brace, Sparco strut brace, HIDs and almost everything blacked out
jmo69 is offline   Reply With Quote
Old 04-07-2017, 10:07 AM   #9
Starvega
My Ride: 323i
The rubber doesn't transfer much heat so it'll be fine. You can actually get stainless steel zip ties for a "more permanent" solution lol
Old 04-07-2017, 11:23 AM   #10
Panzertank831
My Ride: 2002 325xi Sedan
Ive used hose clamps for a "temporary" permanant solution for exhaust hangers. with good results!
Panzertank831 is offline   Reply With Quote
e46, exhaust, gum, repair, vibration
