Old 04-09-2017, 07:28 PM   #1
natE46
My Ride: 2002 BMW 325i
No acceleration at all 325i
I have a 2002 BMW 325i with 200k miles. A few days ago while on the highway my car stopped accelerating & the gear light with the exclamation point in the center came on. I quickly pulled over, shut it off, & read a bit about it. Someone recommended starting the car in neutral which got rid of the light with the gear & !. However, the car still won't shift into any gear or accelerate at all, no check engine light or anything. I've had an on/off problem with the car not shifting into reverse for a while now but its so uncommon that I haven't treated it yet, a mechanic said that was caused by a transmission solenoid. I was wondering if that could have played a role in what happened today or if anyone knows anything that could help me out.
natE46 is offline   Reply With Quote
Old 04-09-2017, 07:58 PM   #2
SSchwab
My Ride: 99 328i, 00 Z3 2.8
Can you start and rev, but not get into gear? Do your brake lights come on when press the brake pedal?
SSchwab is offline   Reply With Quote
Old 04-10-2017, 09:28 AM   #3
goodmanr
My Ride: 01 325i Sprt&PremPkg
The first thing that I would do is check the fluid level.
goodmanr is offline   Reply With Quote
Old 04-10-2017, 09:47 AM   #4
SSchwab
Need more data to assess issue.
Old 04-10-2017, 10:07 AM   #5
GhostFlame
My Ride: E46 Sedan
Definitely change the transmission fluid and filter, if you have not done so already.
Ultimately, you probably need a transmission rebuild, but you could very well go on without one for months / years by just doing the above.
GhostFlame is offline   Reply With Quote
Old 04-10-2017, 05:57 PM   #6
natE46
Yes, it starts & revs, but it seems to stay in neutral. & the brake light works on the passenger side but i need to change the wires on the driver side.
Old 04-10-2017, 07:05 PM   #7
SSchwab
What does it feel like when shift into reverse? Any resistance?
Old 04-11-2017, 06:27 PM   #8
natE46
no, doesn't seem to be
Old 04-11-2017, 06:33 PM   #9
Darios e46
My Ride: 2003 325i sedan
Sounds like you got no fluid in it
I've also seen sheared input shafts do this never seen a sheared input shaft on a Bmw tho
Darios e46 is offline   Reply With Quote
325i 2002, limp mode, transmission
