2004 E46 M3 Lost It's Rasp - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-15-2017, 12:37 PM   #1
E46 Clueless drive
My Ride: Jet Black E46 M3
Hi, I drive an e46 M3 and its been a dream so far, but recently I was driving one day and my engine all of a sudden became quieter. Now instead of rasping at around 2.5k RPMs it rasps at 3.5k and the entire car just sound muffled. It rasps on start up and the first times I reach 2.5k RPMs, then it slowly dies down and stops rasping. I currently have aftermarket headers with cats and a vacuum leak. What could be causing the change in exhaust/engine tone and disappearance/muffled rasp?
E46 Clueless drive is offline   Reply With Quote
Old 04-15-2017, 01:12 PM   #2
tks
My Ride: slower than yours
Vacuum leak
WTB:: Natural Brown Sedan Full Interior
tks is offline   Reply With Quote
Old 04-15-2017, 01:18 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Exhaust cam sensor sloppy?
Old 04-16-2017, 03:08 AM   #4
TobyB
My Ride: 2004xit, 2001ci
There you go!
t
edit- this is a rasp...
Last edited by TobyB; 04-19-2017 at 07:02 PM. Reason: woodworking tool needed label
TobyB is offline   Reply With Quote
Old 04-17-2017, 03:11 PM   #5
E46 Clueless drive
Hey I still don't understand how a vacuum leak would cause a change in exhaust sound, it makes the engine sound weak aswell. Also what is that picture of Haha. I feel like it is something within the engine pistons or something
Old 04-17-2017, 05:46 PM   #6
jfoj
M3's do not have the amount of potential vacuum leaks that a standard E46 would have. I would not expect vacuum leaks to have anything to do with the OP's problem because he is likely WOT around 3k RPM and a vacuum leak would have VERY little impact during WOT operation.
Old 04-19-2017, 01:13 AM   #7
E46 Clueless drive
Im still stumped, my father who used to be a mechanic suggests its my aftermarket catalytic converters not functioning properly causing the muffling sound and lose of rasp.
Old 05-11-2017, 05:07 PM   #8
E46 Clueless drive
Bump Anyone able to help? Could a clogged catalytic converter be causing this problem? THe car has catless headers with an aftermarket catalytic converter placed a little back in the exhaust
Old 05-11-2017, 05:27 PM   #9
avantgarde
My Ride: 2001/2005 325xi A/M
gonna take a shot in the dark and say your exhaust valve timing is off. Probably DME making adaptations? I honestly have no clue, LOL!
avantgarde is offline   Reply With Quote
Old 05-12-2017, 08:21 AM   #10
asianisafish
My Ride: 330ci
Never heard of that happening before
Could it be your just getting used to the car more lol
asianisafish is offline   Reply With Quote
Old 05-18-2017, 03:41 PM   #11
E46 Clueless drive
it happened all of a sudden though, i was driving then my rasp just cut off, like i sensed it cut off while i was driving
choking engine, e46, engine, exhaust, muffled
