Old 05-02-2017, 04:58 PM   #1
BradAllen
My Ride: 2003 325Ci
ECU Fan Guidance
I have a quiet but annoying interior noise. Sound like crickets. On start up and sometimes while driving. I am convinced it's the ECU Fan (firewall near your left foot when driving). The noise isn't bad but if it's failing that's I presume a bad thing as I don't want my ECU to overheat. Has anyone been able to quiet theirs via lubricating it or other means? Or should I just replace it? Has anyone replaced theirs and resolved it to a silent state? I just got the car so I'm not sure if it may not have always made his noise and I'd sure hate to replace it and then find the same noise after all that.
Thanks in advance for any input.
BradAllen is offline   Reply With Quote
Old 05-02-2017, 05:02 PM   #2
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
SolidJake did a video for this a while back - you might want to look at it. I recently changed one on an e83 and it was a PITA to change. I swapped this one cause it had failed not due to noise. Not all e46's got them. None of mine had 'em (I've owned 5 still got 3) BTW seems to be the exact same part across all the BMW platforms.
Edit: you can pull the fuse for the ECU fan to make sure that's the source of the noise before starting to pull anything.
BMW-North is offline   Reply With Quote
Old 05-02-2017, 05:04 PM   #3
My Ride: Lexus
id just replace it. what is it like 20 bucks last time i checked.
Old 05-02-2017, 05:15 PM   #4
BMW-North
Welcome to the forum Brad. Just a word of caution. If you read the quote above you will note two things from it.
1. The poster determined to replace the part without any confirmation that the failure is indeed the part being replaced.
2. The poster really has no clue as to the original or even current price this part retails for.
The part was originally listed by BMW for $144. It is currently available via a popular forum source (FCP) for around $68.
You might be best to ignore advice from this guy in the future. Good luck with your new car.
Old 05-04-2017, 11:45 AM   #5
BradAllen
My Ride: 2003 325Ci
Good suggestion on pulling the fuse to confirm it's the ECU fan before doing anything!
Has anyone been able to lubricate their ECU fan and quiet it?
Or have you replaced yours and found silence?
It's a little annoying but not a lot and I'm trying to decide if I should 1) ignore, 2) try to lubricate or 3) replace. I have plenty of other projects I could do instead!
Old 05-05-2017, 09:14 AM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Replace it if you have the cricket sound. If the fan does fail, or it might have already who knows. It's best to change it so the ECU does not overheat, especially since you're in Cali where the weather is pretty warm..
Here is a vid I made with the job
Old 05-05-2017, 09:30 AM   #7
lingon300k
My Ride: 2005 325xi Automatic
I used Tri-Flow, which is a PTFE/Teflon based bicycle lube. I think I did it late last summer. The noise hasn't come back.
lingon300k is offline   Reply With Quote
ecu, fan, noise
