Old 05-05-2017, 08:02 PM   #1
Piecrust
My Ride: '02 330i 5MT
M54B30 Strange Knocking/Ticking Sound (YT video)
I would really appreciate if anyone could give me any advice. The mechanic says it could possibly be a rod knock?
Piecrust is offline   Reply With Quote
Old 05-05-2017, 11:21 PM   #2
white_335i
My Ride: 03 330i/M3/5/6 spd
Check your spark plugs to see if any of them are loose.
white_335i is offline   Reply With Quote
Old 05-06-2017, 04:47 AM   #3
Lufeco
My Ride: 325iT
Disa valve
Lufeco is offline   Reply With Quote
Old 05-06-2017, 06:34 AM   #4
shoman24v
My Ride: 2002 330i 1999 328is
+1 on checking for loose plug. If it's disa, unplug it. Noise would disappear.
Sent from my Pixel XL using E46Fanatics mobile app
2002 330i 5-SPD - 90k - 1999 328is - 12+ years of ownership, 221k (170k by me) 5-SPD, Factory M Aerodynamic Package, No Sunroof
shoman24v is offline   Reply With Quote
Old 05-06-2017, 10:53 AM   #5
Piecrust
Okay I'll check out the disa when I can but I think I already determined it wasn't making noise. I will look at it again though. Thanks for the advice!
Old 05-06-2017, 11:19 AM   #6
Dude8383
My Ride: 91 332iS, 02 325i
Sounds like a loose plug like the others mentioned...
Dude8383 is offline   Reply With Quote
Old 05-06-2017, 12:58 PM   #7
Piecrust
Okay thanks.
Old 05-06-2017, 04:36 PM   #8
Piecrust
It ended up being a loose plug on cylinder 4. Thanks so much guys.
Old 05-06-2017, 05:28 PM   #9
jdstrickland
My Ride: '94 325iC & '00 323i
You need a new mechanic if he called out a rod knock.
Old 05-06-2017, 07:52 PM   #10
Piecrust
He said it could possibly be a rod knock bearing but also said it sounded kind of strange.
Old 05-07-2017, 01:58 PM   #11
jdstrickland
That does not change what I said.
Old 05-07-2017, 02:00 PM   #12
jdstrickland
Where would you be today if you had taken his diagnosis instead of asking us?
Old 05-07-2017, 02:24 PM   #13
shoman24v
I'd go back to the shop and mention they were wrong.
Old 05-08-2017, 12:28 AM   #14
Piecrust
It would not have been fun experience. And I have already told them what it ended up being.
crank, e46, knock, m54, rod
