Old 05-07-2017, 03:00 AM   #1
Lacd209
My Ride: 2000 bmw
328i wont start
Hello ive been working on my 2000 bmw 328i bought a few weeks ago car was running fine and starting. It does crank over, when i start it will hit about 500 rpm but wont start. I was planning to replace my fuel filter, and was wondering when i disconnect the fuel filter and turn on the power would fuel flow out if it is good?
Lacd209 is offline   Reply With Quote
Old 05-07-2017, 08:23 AM   #2
markusmarkus
My Ride: 2001 330Ci
The first step in diagnosing any issue in a modern car is to scan the computers for codes. Always. Throwing parts at a problem wastes money, doesn't fix the problem and angers the BMW goddesses.
Is the fuel pump original? Test the fuel pressure at the fuel rail test valve. It needs to be at least 50psi at all engine speeds. Item #2 in the link is the cap on the test valve.
http://www.realoem.com/bmw/enUS/show...diagId=13_0644
Old 05-07-2017, 09:38 AM   #3
BMW-North
// Quandt AG (Retired) //
My Ride: AMv8,e46x3,e90,e83
There's a quick disconnect on the fuel rail under the hood that will let you see if fuel is getting to the engine when the fuel pump is energized. You could also try a little quick start in the intake to see if it's a fuel starvation issue. I think there is a thread on here for systematically going through NO Start issues. Maybe it's on page 1 of the general forum as a sticky at the top.
Edit: yep. Second thread down
http://forum.e46fanatics.com/showthread.php?t=1011677
BMW-North is offline   Reply With Quote
Old 05-07-2017, 10:30 AM   #4
SSchwab
My Ride: 99 328i, 00 Z3 2.8
Check the battery voltage and report back.
SSchwab is offline   Reply With Quote
cranks but no start, fuel filter, fuel pump, fuel pump relay, wont start
