E46 Tune removal - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-16-2017, 10:20 PM   #1
celoe46
E46 Tune removal
hey guys I've been a member here for a while but haven't really been active... I have a question? So I had a vf supercharger on my e46 330i and I decided to go back to N/A but I made the mistake of selling the supercharger kit and the flash loader without removing the tune from my car (I know stupid move). I have a shark injector and I know shark injector has a way to remove its file but I'm not sure if it will remove the VF file so can I get the tune removed with the shark injector or is there any other way to remove it?
celoe46 is offline   Reply With Quote
Old 05-16-2017, 11:42 PM   #2
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Have you tried restoring the factory DME firmware with WinKFP? I assume the DME hardware has not been modified.
///Mmmmmm...
Old 05-16-2017, 11:57 PM   #3
celoe46
No i havent. What is WinKFP? And yeah DME hasnt been modified, the VF tune was uploaded through the OBD port
Old 05-17-2017, 12:15 AM   #4
BaliDawg
Originally Posted by celoe46 View Post
What is WinKFP?
This was the first result from Googling winkfp.
https://www.bimmerforums.com/forum/s...or-programming
///Mmmmmm...
Old 05-17-2017, 12:31 AM   #5
celoe46
Yeah i searched it after i replied to you. You think that will remove the tune?
Old 05-17-2017, 08:41 AM   #6
BaliDawg
Yes. It replaces both the code and data in the DME back to factory. What have others in the same situation done?
///Mmmmmm...
Old 05-17-2017, 10:21 AM   #7
MJC12
My Ride: 2001 330i Mtech1
I'd suggest trying to remove your shark tune with the injector before restoring the DME. If you don't and you go ahead and restore the DME, the shark tune will likely be gone for good (when you install a shark tune, the injector itself no longer has the tuned software on it).
2001 BMW 330i
MJC12 is offline   Reply With Quote
Old 05-17-2017, 12:51 PM   #8
celoe46
Thanks man i really appreciate all the info im definitely gonna give the WinKFP a try.
Old 05-17-2017, 12:51 PM   #9
celoe46
Well the shark injector tune i removed it before i added the VF tune to it so were good there.
Old 05-17-2017, 01:00 PM   #10
MJC12
Perfect. I may have misread, I thought you had the shark on there and then added the VF somehow. Good luck!
2001 BMW 330i
Old 05-23-2017, 08:23 PM   #11
celoe46
Hey so i did a ecu update in winkfp do you think that removed the tune? I drove the car but im getting some hesitation now after 4k rpms not sure if thats because the tune is in there or if its something else.
Old 05-24-2017, 01:40 AM   #12
BaliDawg
If you successfully updated with WinKFP, then you saw two phases of programming. The first one was the code and the second one was the data. Yes, the tune is long gone now.
Make sure you clear DME adaptations.
///Mmmmmm...
Old 05-24-2017, 01:21 PM   #13
celoe46
Thank you very much this helped me out alot! Turns out the hesitation was due to a bad maf sensor. I also ended up finding the thread that explains how to use tunerpro, i made my own custom tune now so i know for sure the file is gone and the car is running great. But really thanks for all the help!
330i, e46, file, tune, vf
