Old 05-18-2017, 02:28 AM   #1
jacob92
My Ride: BMW 330CI Cabrio SMG
330ci SMG won't shift in all gears
Hi all
I am a owner of a BMW 330Ci SMG/SSG Convertible, year 2003
After i got some problem with my previous gearbox i decided to change the transmission/gearbox
I bought a transmission that has 75.000 miles on it with pre-installed Shift Actuator, gear postion sensors and a brand new clutch position sensor (the black sensor on the slave cylinder)
After carefully replacement, i used INPA Software to bleed the clutch actuator/Slave Cylinder. All seems to be good.
After that i was calibrating the gear. In this process it is bleeding clutch actuator/slave Cylinder again and then shifting through all gears (sounds right) and after that, i have to start the engine and then it aborted the program?
Anyways..
When starting the car, it gives me a beep signal (like when you turn off the engine), but still looks fine and shows me N. So far so good
Then when i shift to 1 st., it won't drive, it is like N, but i can shift through 2 and 3 gear and drive but 4, 5 and 6 gear is not working (and gives me the CoG light at the dashboard)
Reverse gear is also working good.
So the gear: 1, 4, 5, 6 gear is not working and R, 2, 3 is working
Btw, i cannot go over 4.000 RPM at all when driving?
What cause the problem?
Could it be:
- air in the hydraulic system since i got the hydraulic moved from the old to the new gearbox?
- software/firmware for the new gearbox?
The pump is priming fine and the pressure is about 45 to 49 bar
Please i really hope you can help me!
BMW E46 330CI Convertible SMG 2003
Lexus IS300 2002 - SOLD
BMW E36 316i 1994 - SOLD
Seat Ebiza 1.3 EFI 1994 - SOLD
Opel Kadett E 1984 - SOLD
jacob92 is offline   Reply With Quote
Old 05-18-2017, 03:29 PM   #2
jacob92
UPDATE:
I found out the CoG light.
It turns on when taking around 4.000 RPM, then the light came on and i can't drive more than 85 km/h. then I checked the failure with INPA software.
It gave me following:
51B1 Wheel speed rear axle
Error counter: 1
Logistic counter: 43
Mileage: 186.136 km
Battery Voltage: 13.49 Volt
Actual gear: 1 st gear 0-n
Nomial gear: 1 st gear 0-n
Rel. Clutch position: 0.00 0/oo
Engine speed: 4369.00 rpm
No signal or value
Test conditions fulfilled
Error present now and already stored
Error would cause a warning lamp to light up
Error code: 41 B1 E4 01 2B 5A E3 78 11 00 11 00 00 00 00 00 00 00 00 00 00 00 00
I did also tried manual bleed the clutch now, and the result is the same.
Only got R, 2, 3 gear
1, 4, 5, 6 gear is "missing"
It can show the 1 st. gear but not running, and 5, 6 gear is not showing or shifting into?
Some please help me.
I really want to get my car out running this summer, and I have spend money on a complete gearbox and new clutch position sensor for around 1300 USD
Old 05-18-2017, 04:15 PM   #3
speavler
My Ride: 2004 330i sport smg
this is way over my paygrade, but i recently dealt with issues on my smg myself by replacing the pump as well as battery and alternator. also had gear position sensors replaced a year earlier by my indy. I did not use INPA to bleed the system - just topped off the reservoir and primed the pump about a dozen times. In my little experience with INPA in resetting adaptations, I did have to unplug the battery afterwards to get the engine to run smoothly. Don't know what that was about.
Isn't there a separate process to re-learn the clutch friction zone?
Are you sure the gear position sensors are functioning?
I would also check the hydraulic system for leaks. the clutch actuator is known to leak and i believe there's a rebuild kit for it.
speavler is offline   Reply With Quote
Old 05-19-2017, 01:43 AM   #4
jacob92
Hi speavler
Thanks for your comment and knowledge
I have already tried disconnect the battery, and hold + / - together (car cable side) and i didn't do any diffrence
When doing the complete bleed process with INPA software, it will:
1. Bleed the Slave Cylinder / Actuator - Done
2. Calibrating all the gears (shiftning through all the gears also) - Done
3. Start the engine for learning the clutch biting point - Failing or stuck in process?
I did also check it for leak and as a precaution i did also send the slave cylinder / Actuator to my local store to get it checked/fixed
Could it be the "new" used gearbox that have some issues with the gears?
I can see with the INPA Software it also give me some values when shiftning gears, so i think the sensors should be okay on the new gearbox i mounted?
Hope you can help me figure out!
gear shift, gearbox failure, shift issue, smg, ssg
