Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 01-10-2009, 08:05 PM   #1
Clean_3
My Ride: E46
MAF Sensor causing Transmission Limp Mode?
So I bought the peake tool the other day and pulled the codes(Thanks to Ken for the Great Customer Service from bimmertools!), one of them was the mass air flow sensor the other after being cleared never came back (19 - 27). My question is will a faulty maf sensor cause my transmission (!) to go into limp mode and can the maf be broken by a light hit to it (not directly but the outside plastic). I did search and couldnt get a definite answer on this.
TIA
Originally Posted by BeRzErKaS View Post
You don't know how to spend a half day without your wife?
Try snooping through her things and finding out where she stashed your ballz...
Clean_3 is offline   Reply With Quote
Old 01-10-2009, 09:40 PM   #2
Clean_3
My Ride: E46
Savage BMW wanted $661.49 for the MAF sensor lol ... That place is such a F'n joke and their service Dept is such a ripoff ....
Guess i'll go with ebay or something else because $350 through pelican is still pricey ... so anybody know if these two have any correlation?
Old 01-10-2009, 10:26 PM   #3
richyboycaldo
My Ride: Mx5 300zx 240z 330c
I have a code that says thay my MAF is bad and my car does go into limp mode to.
richyboycaldo is offline   Reply With Quote
Old 12-29-2011, 11:18 PM   #4
DDNPresident
My Ride: 2004 BMW 325i
Send a message via AIM to DDNPresident
any solution to this? Same issue here.
DDNPresident is offline   Reply With Quote
Old 12-30-2011, 12:29 AM   #5
jayinsaney
My Ride: '02 325i topsaublu
A good place to start would be a trip to Advance Auto. I was having MAF errors a while ago and I too was worried that I possibly had to purchase a new sensor. What i needed up doing is buying a can of CRC Mass Air Flow Sensor and cleaning my sensor with it. It's around $8 or so it wouldn't be a bad place to start. Try it, it could potentially save you $$$$.
Happy Holidays,
Jay
'02 325i, Auto, Topaz Blue, 144k.
jayinsaney is offline   Reply With Quote
Old 12-30-2011, 12:32 AM   #6
Guest021715
Account closed.
You have a 2002 325i, which means you can buy the Hyundai Sonata MAF which is the exact same OEM part for about $150.
http://forum.e46fanatics.com/showthr...hlight=hyundai
Old 12-30-2011, 12:51 AM   #7
mack89
My Ride: '02 TIAG 330i 5spd
HHHYYYYUUUUNNNNDDDDAAAAAIIIIII MMMMAAAAFFFFFFF
or get an used MAF from classified forum
mack89 is offline   Reply With Quote
Old 12-30-2011, 10:51 PM   #8
BMWUSMC3051
My Ride: 2000 BMW 323i
Your MAF can cause the car to go into limp mode because it's intertwined with all on board computers in the car do if it's bad it could be the reason also Definently try MAF cleaner by CRC like it was mentioned earlier also u could check the voltage on the MAF and if that's bad buy a new one and put it in yourself haven't hear about the hyundai MAF working but if it does good cuz u won't find one or less then 350 online and instal ur self my local BMW dealer wanted 200$ for mine took me10 minutes to take out clean n put back.
BMWUSMC3051 is offline   Reply With Quote
Old 12-31-2011, 12:32 AM   #9
boyguan
My Ride: 02 330i
I had a limp transmission before and I did replace the maf and it did return. You need to find the code and fix the actual problem. My code was for engine stall speed and I just replaces my engine pulse generator in the transmission. And I hope that will fix it.
boyguan is offline   Reply With Quote
Old 12-31-2011, 02:27 AM   #10
screamer-beemer531
My Ride: BMW M3 E46 6spd PY
Happy Holidays,
Jay
+ 1 I had a MAF issue once and a mechanic friend cleaned it for me. I was about to replace it. It startles me how some people replace them when all they need is cleaning. This isn't always the case however some people lose hundreds because they didn't know this.
"Failure is simply the opportunity to begin again, this time more intelligently." Henry Ford
screamer-beemer531 is offline   Reply With Quote
Old 01-05-2012, 07:25 PM   #11
DDNPresident
I have cleaned both maf and connector in a previous attempt. No change. Quick question... When my maf is unplugged there seems to be no change in the car at all. I have even unplugged it while running expecting it do die out. No changes at all. Anyone know if this is normal. Doesn't seem normal.
Also, I have been trying to search around how I can test this maf with a multimeter but there has been no definitive answer. I need to know what the colors mean on the 5 wire maf. Also, would should the values be if i am testing between the wires. While I am there it would also be helpful for me to check the harness as well, but I need a little help finding what to look for. Any thoughts?
Old 04-18-2012, 02:16 PM   #12
vol96
My Ride: 2000 328i
Any solution yet?
vol96 is offline   Reply With Quote
Old 04-18-2012, 02:26 PM   #13
Stinger9
My Ride: '04 330Ci
New doesn't have to mean expensive
http://www.bmaparts.com/ShopByVehicl...=True&rewrite=
Old 04-18-2012, 05:38 PM   #14
silyb0y
My Ride: E46 330
Hi guys. I have read that the automatic transmission needs a correct signal from the maf to work correctly. Over here some tranny specialists have even claimed that a faulty maf can kill the tranny. So - if the codes say that maf is faulty - dont drive around like that for too long. Limp mode? No idea.
How can you check maf? Use OBD to read out air mass (according to maf) and check if the numbers make sense.
silyb0y is offline   Reply With Quote
Old 03-17-2017, 12:02 PM   #15
Tcleaver
My Ride: 2003 325i
Just got my car scanned, called for MAF, one can find the MAF online for $25-30 used or like the previous posts the hyundai ones work the same. If you simply type in the PBT-GF30 PN online you can find multiple vehicles that use the same part and find the best price.
Just cleaned my stock MAF, hoping it works out to clean up limp mode. Will know in a few.. Otherwise ill be out $150 or so..
Tcleaver is offline   Reply With Quote
Old Today, 02:50 AM   #16
SlammedCRx
My Ride: E46
E46 limp mode.
How's it running ?^^^
I got a egs code and ews code and mass air flow code! Car starts fine and drives in 3rd. Any thoughts ?
SlammedCRx is offline   Reply With Quote
limp mode, maf, transmission light
