Thread Tools Search this Thread Rating: Thread Rating: 308 votes, 5.00 average. Display Modes
Old 05-07-2016, 04:28 PM   #81
BMWCaptain
Location: TEXAS - Circuit of the Americas doing laps with my M5 and coming in for a pit stop.
My Ride: 03 330iT SportWagon
Originally Posted by jryeje View Post
Just got my transmission rebuilt, and that included getting a new torque converter as well for anyone wondering, seems to be the main culprit
What did it cost?
BMWCaptain is offline   Reply With Quote
Old 05-07-2016, 04:33 PM   #82
jryeje
My Ride: 2002 E46 330i
Originally Posted by BMWCaptain View Post
What did it cost?
The rebuild was $1400 for the full rebuild kit and labor but then on top of that any special parts that were broken were added costs. For me it came out to $2600 because I needed a torque convertor which was $400 for a new one and a couple other parts. It really hurt having to pay it outta nowhere but now it drives great and I have a two year warranty on it. I hope that helps a bit.
jryeje is offline   Reply With Quote
Old 03-01-2017, 09:58 AM   #83
rsyed07
My Ride: E92 335is, E46 330i
Thread revival.
So from reading all this first try to reflash the TCM, if that does not work buy a used one that has similar numbers and then get it programmed at an Indy? My E46 is having the same issue as many on here. Car slips when taking off until a loud thump then its stuck in 4th gear limp mode with red cog of death sign.
rsyed07 is offline   Reply With Quote
Old 03-07-2017, 12:07 AM   #84
Ki30
My Ride: 00' E46 328i
Same kind of issue
Hey I'm having an issue with the AT.
Started out of no where which leaves me to believe its a technical issue related to some kind of malfunction of computer or something.
Was driving the car for like 15-20 minutes perfectly normal and then out of the blue it started shifting abnormal, revving high before changing gear or not wanting to change at all. Then as the car got to operating temp the transmission light popped on and went into "safe mode" stays in 3rd gear. I can turn the car off for like 5 minutes and it flicks off the light and will shift fine again for another 10 or so minutes before doing it all over again.
What could cause that?
I say it's not the gears themselves went bad cuz the trans has shifted smooth as butter before this issue just happened out of no where when I started it and drove it the other day.
Ki30 is offline   Reply With Quote
Old 03-07-2017, 12:38 AM   #85
Infamousredrum
My Ride: Murdered out 330
Just an idea but what about the tranny temp since when cold still its fine... Have you look at the tranny thermostat under the expansion tank maybe its broken perhaps? Im no expert but just a idea
Infamousredrum is offline   Reply With Quote
Old 03-07-2017, 01:20 PM   #86
Ki30
I doubt its that, I just recently had my whole coolant system done...an update to the situation is the problem seems to be getting worst. Not leaking anything, but after I drive for a short time I smell a burning smell. And now when I go in reverse or forward the hard will rev up before engaging the gear, sometimes will even buck into gear. And when it starts going itll rev out high to about 4000rpm before even changing gear. Then stay at about 3500rpm and change again rapidly to about 4th gear and it doesn't seem to be giving me as much power as I used to have, hardly any throttle response. I just had the car full tune up all new coils and plugs no misfires or check engine light on...which is odd, clearly something is wrong but the check engine light hasn't come on at all, even when the trans light comes on.
This has me stumped, I'm gonna take it off the road for now till I get some extra money, cuz I have a feeling the transmission could be done for
Old 03-07-2017, 05:07 PM   #87
delgadilloalex
My Ride: 2001 325Ci
I had similar issues.
I had a clogged trans cooler. Burnt the fluid. Once it's burnt you have to change it.
Have you ever changed you're atf and filter?
Sent from my SM-N900T using E46Fanatics mobile app
delgadilloalex is offline   Reply With Quote
Old 03-08-2017, 06:52 AM   #88
Ki30
I've topped the ATF here and there when it needed it but I've never drained and changed it completely.... I didn't even know there was a filter for that...so the answer is no lol, how would I do that? Its a 2000 328i.
What ATF fluid do you recommend?
Old 03-08-2017, 07:10 AM   #89
Eurobahn BMW
Eurobahn BMW
Eurobahn BMW's Avatar
My Ride: BMW Greensboro
Majority of the time low voltage will cause these faults. Once replacing your battery, reseting the adaptions on your vehicle will resolve this issue. for more info http://www.eurobahnm.com/
Eurobahn BMW MINI Mercedes Benz Audi of Greensboro is your local independent BMW Greensboro We offer BMW service at the dealer-level Service & expertise at a fraction of the cost at our BMW Greensboro dealership.
Eurobahn BMW is offline   Reply With Quote
Old 03-08-2017, 08:06 AM   #90
Ki30
My battery is a year old, would it go that quickly?
Is it possible this issue is caused from using the wrong ATF fluid?
I recently topped the ATF off, about a week or two before it started happening.
I read that its slipping because the transmission temp is getting hot which is why I smell burning.
Old 03-08-2017, 09:11 AM   #91
Ki30
Battery voltage is 12.5 when not running and 14.3 when running ATF fluid I used was valvoline multi vehicle import ATF shows on the bottle its for BMWs...the ATF level is fine so is the engine oil and coolant. It has to be something with the transmission itself, I started it up one day and it just happened it wasn't gradual at all, out of the blue. This has me stumped... I don't wanna sell her if its an easy fix please help!
It feels like a slipping clutch. I put it in reverse, hit the gas and it doesnt move for like a second or two then grips gear and goes. Same with forward. I've had issues with it not going on reverse at all and after waiting a little bit starting it up again it'll engage. Just for some more info about the car.
Old 05-05-2017, 06:20 PM   #92
pat13524
My Ride: 2005 325i
I have same problem as many on here (pretty much everything Angel said):
- Feels like its starting in 3rd and has no power/abnormal shifting (when in limp mode)
- Death clog randomly comes on after about 10-20min of driving
- OBD scanner prints out
+ P0174 - System Too Lean (Bank 2)
+ P0171 - System Too Lean (Bank 1)
+ P0700 - Transmission Control System Malfunction
+ P0734 - Gear 4 Incorrect Ratio
- After resetting the codes, immediately car shifts normally and has no problems
- Trans fluids are topped up
- No other dash lights are on (sometimes check engine comes on with the gear but not always_
pat13524 is offline   Reply With Quote
egs, limp, tcm, trans, transmission
