Thread Tools Search this Thread Rating: Thread Rating: 55 votes, 4.93 average. Display Modes
Old 01-02-2015, 02:18 AM   #81
Blademan
My Ride: 2000 328i
Good advice on feeling for the hot and cold cooler lines.
BaliDawg method is disconnecting at the cooler end, near the #1 in the realoem link.
Lugerhead is your method to also disconnect the colder cooler line at the heat exchanger end? #1 in the realoem pic?
Confirming NOT to disconnect lines at the transmission.
Blademan is offline   Reply With Quote
Old 01-02-2015, 02:39 AM   #82
Blademan
My Ride: 2000 328i
On the realoem pic, are the hoses labeled "OIL COOLING PIPE INLET" and "OIL COOLING PIPE OUTLET" from the transmission perspective or the cooler perspective?
Old 01-02-2015, 01:23 PM   #83
Lugerhead
My Ride: 01 325IT 89 325IS
Yes, disconnect the cooler line at the cooler, I think it's the passenger side, and leave the other one connected. That will leave you a nice nipple on the cooler itself to slip the hose on that goes in your bucket / jug, what ever you are using. Don't mess with the hose connection at the transmission. The real oem parts list does not say which is outlet inlet. That's where the feeling of the lines comes into play. The one that is the hotter needs to stay connected to the cooler and remove the cooler line.
Lugerhead is offline   Reply With Quote
Old 01-02-2015, 03:14 PM   #84
BaliDawg
Keepin' it real stock
My Ride: E24 E32 E46 E39 E84
Originally Posted by Lugerhead View Post
...disconnect the cooler line at the cooler...and leave the other one connected. That will leave you a nice nipple on the cooler itself to slip the hose on that goes in your bucket...
Good idea. I was always disconnecting both hoses. Doh! But obviously it's easier to just disconnect one.
Some time ago when I was figuring out this flush methodology I searched around for a DIY and found none. One of us should do one and post it on this forum.
///Mmmmmm...
Old 01-02-2015, 05:11 PM   #85
DEADF15H
My Ride: 2001 325i Auto
Please do!
DEADF15H is offline   Reply With Quote
Old 10-28-2016, 12:34 PM   #86
EthanFreedlund
My Ride: 2003 325i
Links of great info.
Video of this trans flush on an Opal. 1 of 2
https://youtu.be/tno0NfJmsSo
And this is the entire sheet on this transmission.
http://pro-ht.mbnet.fi/Kuvat/automaattilaatikko/5L40E.pdf
Two perfect tools to flush this transmission at home.
EthanFreedlund is offline   Reply With Quote
Old 10-29-2016, 02:41 AM   #87
EthanFreedlund
My Ride: 2003 325i
Lugerhead, any idea on the size of tubing you used to slip on to the heat exchanger? I know it's been a while since this post but I am about to go buy some tubing and was just curious if you remembered the size? Mahalo!
filter, fluid, lucas oil, skipping, transmission
