Feeler FS:2001 330xi sedan 5-speed - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Complete Cars - Private
Old 04-24-2012, 09:02 PM   #21
jogfrogjog
My Ride: car e46 330xi
RELISTED!!! Lower buy now and reserve price... bid or make an offer, trying to sell by Thursday!!!
http://cgi.ebay.com/ebaymotors/ws/eB...t_18209wt_1182
jogfrogjog is offline   Reply With Quote
Old 04-25-2012, 05:59 PM   #22
jogfrogjog
bump
Old 02-24-2013, 01:43 AM   #23
jogfrogjog
Looking to sell this. Since the original post, the car has now 178k on it. I replaced the rear diff bushings with AKG bushings. I also replaced the missing taillight with a new unit, had an indy shop look over the car and replaced the upper rad hose after pressurizing the system and found a small leak in the upper hose. We also discovered an oil leak and found that it was from the oil filter housing gasket and replaced that and the engine has been dry on outside since. I'm in Santa Rosa, California now. I haven't changed the plates over yet, but just took it and got it smogged today and it passed with flying colors. I also just picked up a set of powerflex control arm bushings that I'm hoping to install to replace the old control arm bushings in the next few days. Car is in great shape mechanically and mechanically I wouldn't hesitate to make a trip with it across the country. Let me know if you have any questions.
Old 03-01-2013, 02:05 PM   #24
jogfrogjog
Bump, open to offers, just replaced front CABs with powerflex bushings. Car is ready for trip across the country. Oil changed about 1000 miles ago with castrol full synthetic and genuine BMW oil filter.
Old 08-20-2013, 06:59 AM   #25
jogfrogjog
Just replaced clutch and flywheel with UUC lightweight flywheel and e34 m5 clutch. Replaced pilot bearing, throwout bearing, driveshaft center support bearing (I think this was the cause of the clunking in the rear), replaced the diff with one that has 50k miles on it according to the seller with fresh redline gear oil. I also refreshed the shifter with a UUC short shifter and replaced the coupling attached to the transmission with a fresh oem unit. I also removed 3 of the 4 old exhaust studs on the end of the manifold and replaced with new stainless steel hardware.
At about 3k miles ago I replaced the water pump with a Stewart water pump and new belts and under drive pulley for the steering pump.
The car now has 183k on it. Replaced the front CAB bushings a bit ago and have AKG rear subframe bushings that are waiting to replace the oem ones.
I also replaced the grill recently with black inserts since one of my oem ones broke and fell off.
Old 10-12-2014, 10:09 PM   #26
jogfrogjog
bump this up... price drop to $4500 OBO. Moved back to the east coast in PA/NJ. I've replaced the suspension with eibach springs and koni adjustables all the way around with new top hats and reinforcement plates in the rear for the shock towers with heavy duty rear shock towers. What the car needs now is front rotors and pads and valve cover gasket. The car has 200k on it and I'm still driving to work which is about 140 miles round trip. I also replaced the rest of the cooling system a few months ago, I had a slow pin hole leak in the radiator so I was lucky enough not to run out of coolant and over heat the engine. So new Behr radiator and new expansion tank and temp sensor and hose. Also replaced the driverside motor mount around the same time as the radiator.
I also finally got around to removing the bumper sticker on the back as can be seen in pictures below. (YAY!!)
Old 10-17-2014, 09:41 AM   #27
OfTheLost
My Ride: 2000 328i
Free bump because this post made me chuckle. Props for being determined to sell a car for almost 3 years lol. You seemed to have replaced so much since your first post... I'd almost just drive it into the ground at this point.
2000 BMW 328i
1995 Honda Del Sol SI
OfTheLost is offline   Reply With Quote
330xi, 5-speed, e46, manual
