Old 03-28-2013, 07:13 AM   #1
ybw
My Ride: BMW E46 328
Question RPM problem when engine cold
Hi all!
I have BMW e46 328i 1999y.
In cold weather. When I start engine, I get problem with RPM. ().
RPM is jumping from 400 to 1200.
Sometimes go to 0 ;( and after start again get a 1200.
When engine overcomes 80, engine work normal 700RPM
Can you get a some right path to find solve this problem please._a_
ybw is offline   Reply With Quote
Old 03-29-2013, 03:18 AM   #2
ybw
That's how subside today morning
Old 03-29-2013, 01:47 PM   #3
jdny516
My Ride: Oxford Green M5
Vacuum leak somewhere? Are you throwing codes? MAF cleaning? ICV?
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Frank Smith Tune
TTFS Alpha N
SuperSprint Headers
SuperSprint X-Pipe
DINAN Front Strut Brace
Storm Motorwerks Products
2003 BMW X5 4.6iS | Black Sapphire Metallic | Black Sport | Titan Trim
2000 323Ci | TiAg | Gray | 5MT | SOLD My Progress Thread
jdny516 is offline   Reply With Quote
Old 03-31-2013, 06:11 PM   #4
lszlszx
My Ride: 1.8T, XC70
Worn Vanos seals can cause that, mine does the same thing, I'll be replacing those before next winter.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 07-08-2014, 03:26 AM   #5
JimsE46
My Ride: E46
Hi my e46 320i has the same issue. Have you solved this problem yet?
JimsE46 is offline   Reply With Quote
Old 07-08-2014, 07:29 AM   #6
ybw
Clean fuel system.
Check and replace/repair VANOS.
Old 07-10-2014, 03:16 PM   #7
BartenderPlease
My Ride: '03 540i/6 M-Sport
My 1999 328i used to do that, then it got so bad that it would stall out. I replaced intake manifold gasket, disa gasket, throttle body gasket, valve cover gasket, VANOS seals, entire CCV system, and MAF. It idles 100% better than it ever has in my ownership (because it always dipped on cold start, needed VANOS seals from day 1)
.............................................@jb540i6
'02 JR/Naturbraun 330i M-Tech I | M-Tech II Fr. | Supersprint Headers | Remus Sport |
.....| SM Flywheel Conv. | 18" CH'ish reps | Short Shift | Orion V2.5 | RCR LED Tail |
'03 JB/Schwarz 540i M-Sport 337 | Decatted | Short Shift | Carbon Trim | JL Audio | V1
BartenderPlease is offline   Reply With Quote
cold, engine, problem, rpm
