Old 04-09-2013, 10:11 AM   #1
Dudewhereismycar
My Ride: 2001 BMW 330i
2001 BMW E46 Driver Side Window Wind Noise
Hello Fellow Dudes,
My 2001 BMW E46 330i has an annoying wind noise when driving above 45mph. It gets more apparent when cruising on freeway above 70mph. I have changed the door seal and checked the mirror. The problem still hasn't gone away. My BMW certified mechanic said he is not sure either.
Do I need a window adjustment? This really takes away my Farfegnugen!
Dudewhereismycar is offline   Reply With Quote
Old 04-09-2013, 10:15 AM   #2
TheJonRoss
My Ride: 2002 325xi, 2005 X5
Fahrvergnügen is for VW's, you're in freude am fahren territory!
My side mirrors make a whistling wind noise, but I only notice it when the windows are down.
Welcome to E46Fanatics!
-Jon
BMWCCA# 473325
Join the Experience
TheJonRoss is offline   Reply With Quote
Old 04-09-2013, 05:25 PM   #3
lszlszx
My Ride: 1.8T, XC70
Das ist nicht gut!
Next time you was the car, drench the window area, if the air can go through, so can the water. If it's the window, the water will get on the inside of glass.
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 04-09-2013, 05:48 PM   #4
Toad21
My Ride: 00' 328CI
I have the same noise. It is most likely caused by the window not fully seating into its sill. I am not sure what the fix will be, but I am interested to hear.
Toad21 is offline   Reply With Quote
Old 04-09-2013, 10:56 PM   #5
illmatic37
My Ride: 330ci, 635csi
Try this DIY
http://forum.e46fanatics.com/showthread.php?t=927855
Maybe all it needs is an adjustment_nr_
illmatic37 is offline   Reply With Quote
330i, door seal, e46, wind noise, window
