Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Lighting & Mobile Electronics (I.C.E.)
Xenon lighting, HID kits, fog lights, BMW head units, navigation, speakers, subwoofers, In Car Electronics (I.C.E.), carputers, DDEs, angle eyes, halos, LED tail lights, interior lighting, etc.
Old 04-12-2013, 12:20 AM   #1
CJin2552
My Ride: 2001 BMW 325Ci
WTB: Xenon Headlights
I'm looking to buy some Xenon Projector headlights. I'd prefer them be RetroFitted, just because I don't care to try and rig up D2S in a 2001 BMW 325Ci that came stock with Halogen headlights.
I'd need them to be made for a:
-323Ci (Coupe/Convertible)
-325Ci (Coupe/Convertible)
-328Ci (Coupe/Convertible)
-330Ci (Coupe/Convertible)
ALL PRE-FACELIFT
I currently have the headlights with the black trim around the lights, but I do not mind the silver trim, as long as everything matches.
CJin2552 is offline   Reply With Quote
Old 04-12-2013, 05:51 PM   #2
jack.chris328
My Ride: is a truck.
Just FYI. If you get a set of OEM lights you won't have to "rig" anything. They use the same style plugs to attach to the car harness. The only thing you would need to do is get a set of inline cancelers that are plug and play and you are set to go. If you don't want to use the cancelers then you can just get your care re-programed for xenons. I have a set of OEM bi-xenon coupe ones that would work for your car. But you would need to change the corner lights. As 1999 - 2001 used the "clip-in" style corners then 2002 - 2003 used the "screw-in" type corners. All look the same from the outside and fit the fender the same way. Only difference is how it attaches to the headlight housing. Let me know if you would be interested in those
jack.chris328 is offline   Reply With Quote
Old 04-12-2013, 05:56 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
If you can't find a set of OEM headlights then click projector retrofit in my sig
Old 04-12-2013, 11:15 PM   #4
CJin2552
Would you mind maybe private messaging me some links to pictures of the sides of the housings/assemblies? I have one OEM Xenon assembly that I got out of a salvaged 330Ci Convertible. I'm pretty sure it was a 2003 model, but the sides show that the 'clip-in' corner lights would work.
You wouldn't happen to know how to set all of that up would you? I've heard bad things about putting D2S style bulb systems into cars like mine. I've heard a bunch of things about flicker issues and stuff. If you could provide a walk-through, that would be greatly appreciated.
Old 04-12-2013, 11:19 PM   #5
CJin2552
I greatly appreciate the RetroFit advice. I love how you painted everything matte black. The only thing I worry about with the RetroFitting my reflector assembly is where to screw in the new projectors, and where I need to cut off the backs of the reflectors, so that the projectors can fit. Those are two of my main reasons why I haven't begun a RetroFit yet.
Old 04-12-2013, 11:34 PM   #6
jack.chris328
No problem. Will do.
Old 04-12-2013, 11:40 PM   #7
CJin2552
Thanks, I appreciate it.
Old 04-13-2013, 03:41 AM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
You don't need to cut anything on the headlight assembly itself. That DIY was done by someone else but I made a vid on how to install them. Only cutting needed is trimming down the shrouds. Check it out
Old 04-13-2013, 03:43 PM   #9
Asmod3us
Regional Sponsor
My Ride: M3
Send a message via AIM to Asmod3us
got a pair for $700 obo, COMPLETE, OEM, good shape!
PMme
Part outs, parts, cars, etc: Asmod3us's FS Threads
Lots of parts on eBay: eBay Auctions
Asmod3us is offline   Reply With Quote
325, assembly, headlight, retrofit, xenon
