Old 07-20-2013, 10:22 AM   #1
bullet350
My Ride: BMW 320i
Unhappy Increased cabin sound
Hello everyone, Took my car in for a tire change and also got the air con filter cleaned. All of a sudden the cabin sound has increased. Like more engine sound is coming thorough. Note: it's not vibration. Outside, standing next to the car sound is the same only more sound inside the cabin.
Any thoughts? Many thanks,
Car: 2001 320i
bullet350 is offline   Reply With Quote
Old 07-20-2013, 10:25 AM   #2
Dave1027
My Ride: '06 IR zhp coupe
I'd be concerned the tire shop f'd up your cabin filter housing. It's probably something they did.
Old 07-20-2013, 10:26 AM   #3
conrad721
My Ride: E46 325i 320i 330Ci
which tire brand did u buy and which variant?
conrad721 is offline   Reply With Quote
Old 07-20-2013, 10:30 AM   #4
bullet350
My Ride: BMW 320i
Thanks Dave, what do you think I can do to confirm if its the housing? Thanks,
Conrad- Michelin, same as I had before. I don't think it's te new tires as there are no vibrations. Thanks
Old 07-20-2013, 10:32 AM   #5
BimmersGarage
My Ride: E46 330i
What brand/model of tire..?
If it's an aggressive tread pattern... that would be the reason. Also, if they air it up wrong, either too much or not enough air. You need to double check it yourself.
One last thing - You should Always get your suspension checked and then get an Alignment (by a BMW knowledgeable shop) after getting new tires.
NOTE:
Your tire shop may have not balanced the tire(s) correctly.
BimmersGarage is offline   Reply With Quote
Old 07-20-2013, 10:35 AM   #6
bullet350
My Ride: BMW 320i
Thanks BimmerGarage, it's Michelin same type as I ha before. I don't know about the pattern. Should be the same I guess.
The tires were aligned using their bmw computer.
Old 07-20-2013, 10:36 AM   #7
Dave1027
It could be something as simple as a rubber seal that got knock out of place. Give it a really good visual. If it's not obvious then maybe take it back to the tire shop and have them check their work.
Old 07-20-2013, 10:33 PM   #8
My325XI
My Ride: 03 325XI Sprt Prem
I'm thinking along the lines of post # 2. Maybe the cabin filter is not seated correctly, maybe the cabin filter cover is not on correctly.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Old 07-21-2013, 11:02 AM   #9
bullet350
My Ride: BMW 320i
Thanks, on checking again, the cover of the filter was ajar. I closed and tightened it. But sound sill remains. It's more on revving the engine. Thanks and i appreciate te help
Old 07-21-2013, 12:24 PM   #10
eweis
My Ride: 1999 328i
Back to the top for a moment......what's an air conditioning filter? Do you mean cabin filter?...or something else.
eweis is offline   Reply With Quote
Old 07-21-2013, 09:32 PM   #11
bullet350
My Ride: BMW 320i
Thanks, its the cabin air filter. Any thoughts?
About the sound: At idle, sound is near normal inside the cabin, once the engine revs up say around 2k RPM the sound increases and is quite loud. Outside the car, next to the engine, sound is completely normal.
Appreciate any thoughts.
cabin, sound
