Problem: My E46's D99 Dynavin (WinCE 5) doesn't want to process video in, so it's become a toshiba ARM 2440 MCU experimenter board that looks like bmw parts to play with, but a car without head.
Solution:I'm going to install a carpc with the following specs on my 2003 330xi.
I ordered the E46 Xenarc bezel for the 700TSV from Janus.
Everyone, including Kenishi over there says it works with all Xenarc 7" monitors, but I'm getting sticking with the TSV. I'm going with Xenarc over liliput for the linux support and because I like the look better.
aux headphone in
Remote start/heat:
Programmable Button:
PC PWR:
Ignition Kill switch:
Jump switch:
Joycon EXR Steering Wheel Control PC Interface
(can I just use rolfs ibus interface?)
USB
Displays
Power
Chassis:
Compaq CQ2009f
Bluetooth:
Wifi:
3g/4g:
HD Radio
FM/ATSC/NTSC/Q-CSb?
Ham/UHF/VHF/Scanner/XMIT/etc.
Dashcam:
R310 2.7-inch 140 degrees Dual Lens dash board camera car dvr black box video recorder + gps logger
32gb memory card
I want to run ride runner on win 7 with backtrack on vmware.
I want to have convention windows and linux operation, with the ride runner frontend.
I haven't picked navi software but I need that.
I also need to figure out and photograph the Harman Kardon amp hookups, because the dynavin just used the fakra cable, but the carpc has to take over all that.
It's be cool to put a roof rack with removable solar panels and storage for a bike genset, but weapons storage and a yakima box for cargo comes first after carpc.
What am I missing from this list?:hmm:
aux headphone in
Remote start/heat:
2 Channel Programmable Remote Control Momentary Switch
Function:stealth switch (all lights off, mute audio), performance switch (change timing, turn off ac, etc.)
1xSilver Stainless Steel Momentary Pushbutton 16mm
PC PWR:
1xBlack Latching Pushbutton Automotive Switch 16mm
(have to figure out where to connect)
Jump switch:
Function: batt 1 to batt. 2 connect/UPS(PC+Amp) to batt 2 disconnect
Material: 1xBlack Latching Pushbutton Automotive Switch 16mm
Relays
Relays
USB
dc-dc converter
Powered wrt-54g dd-wrt AP
Powered USB Hub
USB A female to motherboard header adapter
15' USB cable
2.5-Foot USB Male to male cable CBL-BLK-USB-AMAM
Powered USB Hub
15' USB cable
Displays
Janus Designs Bezel
Xenarc 700TSV 7" TFT LCD Touchscreen Monitor New 2010 Model
Xenarc 700 Series extra long Monitor Cable 5 Meters (16.4 feet), New Version, 26 Pin
VGA duplicator
15" acer monitor
ergonomic arm
VGA duplicator
15" acer monitor
ergonomic arm
Power
Mini-Box SFX / ATX enclosure for M4-ATX
M4-ATX 250W Intelligent DC-DC PSU
M4-ATX USB Cable 3'
Mini-Box picoUPS-120 ATX DC micro UPS system / battery backup system for 12V automotive enviroments.
12V battery for ups and jump start button
M4-ATX USB Cable 3'
Chassis:
Compaq CQ2009f
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3887062
Foxconn H-I945-ITX mini-itx mobo
1.6Ghz single core Atom 230
64GB SSD
2GB DDR
gma 950 graphics
realtek alc662 audio
10Mbit LAN
64GB SSD
2GB DDR
gma 950 graphics
10Mbit LAN
Bluetooth:
USB stick
Wifi:
Alfa usb wardriving kit (use with backtrack)
3g/4g:
tethering via bluetooth, usb, or actual 3g/4g+sim i don't know yet
HD Radio
MJS HD Radio USB PC Interface Cable
Visteon HD Radio Component Car Tuner Kit
FM/ATSC/NTSC/Q-CSb?
USB stick
diy radio box
Dashcam:
32gb memory card
