Hello folks! I'm just looking for all the "e46ers" in Kansas.... I feel so left out :bawling:. I cant find anyone else that does these cars around Johnson County! Met a really cool guy awile back and will be meeting him next weekend you can find his thread here: http://forum.e46fanatics.com/showthr...664&highlight= . Other than him the only other person I know Has a 325xi with cheap ass wheels and hes a total douche! HE EVEN KEYED MY CAR AND IS TELLING EVERYONE I COPIED HIS "CAR IDEAS" AND MODDED MY CAR WITH HIS IDEAS BEFORE HE DID! :ben: :censor:. So anyway calling all Kansas E46 Fanatics!
I'm looking at houses for rent, any good leads? Must have a garage, 2 bedroom min, and not break the bank. Dont need anything super fancy, just safe area where I wont get mugged, lol.
They only come in a really staggered size. so unless you want to run 4 rears, you'll be running 19x8.5 front and 19x10 rear. Offsets are really agressive too. I'm running a lot of rear camber to compensate.
So I took the M3 out yesterday to see what the new brakes and tires were like. The brakes are insane, very impressive. But it seemed that I had a bit of an issue with stability. The front shocks were set at full soft, and I though maybe that was part of the issue. A Mr. Perkins confirmed my suspicions, so I set the front to mostly stiff, and the rear to just over half stiff.
Went out again. The car was much more stable, and braked even harder since its a little warmer today. :woot:
I have a feeling you have a lot to do setup wise but youre getting there. I think you still need to adjust you camber and possibly your sways, I can't remember what you had those at.
Yeah, I've been thinking about all that. I feel alot better now knowing that my tires and brakes are solid though.
Sways - set in the middle up front, IIRC. and I don't even know what in the rear. I need to install my new rear endlinks so maybe I'll take a look at those then.
Camber - running -2 in the rear all the time, I know that much. I need to get some front plates ordered. I don't think I'm going to go for new springs yet.
Toe - I gotta get some negative toe in for my street setup. The tram lining is really bad...
I want to get some of those quick-fit harnesses ordered. Fan will go in sometime next week. I think I'm also going to skip the Bimmerworld tune, unless my dyno comes out being really off. $600 is alot of money for something that I may not need and can always do later.
I'm not sure what sways you have or how much adjustment they have but you will want the fronts stiffer than the rear as a common rule.
Another general rule for the M3 is that you want to run atleast 1 degree more negative camber up front than in the rear. This doesn't really matter as much for street driving but will make a big difference on the track. So -2 in the rear means you should be around -3 up front. Now there is a point of to much (for the rear), I would never go over -3 in the rear. I plan to run -3.8 front and -2.5 rear and use my pyrometer to adjust it from there. Without a pyrometer the best chance you have at finding the right amount of camber is by the tire wear eye test.
Yeah I would for sure dyno and see where your AFR's are, if they are good then it's not like you "need" the extra power.
So I'm working on finalizing my alignment settings. (I realize I'm over simplifying things)
For the street setup, how much negative toe should I run? I don't want to burn through tires...
Kevin was running -3/16" rear. The Bentley service manual specifies 0°22'... but I have no idea how to relate these two numbers. :rofl:
Come on now you can't translate inches into degrees, minutes, and seconds? I thought you wanted to be an engineer, lol. You should be able to find a conversion tool online that will do it for you.
For the front I figure just align it to 0 toe at 3.5°, so when I pull the camber back out to -2 or -1.5 the toe comes in.
You want toe out front not toe in. What you want to do is align at 0 toe at street camber then it will toe out when you go to -3.5 for the track. I know you want to add toe for tramlining but you either have good street tire wear and tramlining or bad wear and not tramlining. If you have toe at you street camber setting it will more than triple at your track camber setting which will scrub of speed and rubber. As far as overall toe settings I can't remember what I did but Kendal should have both Kevin and my alignment. I set mine at what James recommended.
You're on the right track though, half of it is just knowing what you have so you can make changes from there. Make sure to get a little note pad and put your settings in it. Then make notes of how the car feels and handles. If you make changes, not them, and what changes they made to the car in terms of feel.
I've been working on it a little bit here and there and I'll probably have the diff back in today or Friday. I will still have to button everything up though and do a few more things before I can take it for a drive. You're more than welcome to come hang out and help Saturday.
My diff was just delivered, I can't freaking wait to get this thing in and get the car back on the ground.
I just had a great idea for next winter. My plan is to get a cage built and fully welded in and I want to paint in some obnoxiously bright color. I just got the idea of powdercoating every part I can in a matching color, just cause.
I spoke with Kevin on the phone and I need to clarify something. If you care about a comfortable ride or tire wear please do not ask me questions. Now if you care about performance then ask me all the questions you want.
With that disclaimer said, first of all I meant I would NEVER recommend toe in in the front. Toe in is appropriate and needed for the rear. Toe in in the front will reduce tramlinning but in all situations, track or street, will increase understeer. Toe in front will increase understeer toe in rear increases oversteer. Increased oversteer in the rear (to a degree) is a good thing because it helps rotate the car.
Sorry... been out of the loop the past 2 days (had to drive to Kirksville yesterday for work...in the company car :woot: )
After catching up I have 3 questions...
1. So what would the absolute alignment settings on the ///M be? I am getting an alignment ASAP (whenever she is off the stands). Right now I am thinking:
Front: -2.2 Camber 0 Toe
Rear: -1.8 Camber ?? Toe
This is all relative as to making my wheels and tires fit without rubbing
2. Car being up on jack stands leads me to ask... Who wants to come lend me a hand on installing headers and new radiator :banghead: ....I got beer??
3. See #2
4. Brad since you are "ahead" of schedule will she be making the meet? Also took apart the radiator last night... the plastic supports are the only thing messed up not the actual fins or radiator itself... but not sure if radiator can be "resealed" after removing plastic supports the way the tabs fold over from factory?? Make sense?
Depends what you want. Pure track performance, street comfort, good tire wear, or a combination of the three. You just have to understand that a combination of the three sacrifices a bit on each. In your case I would just run whatever camber you need to fit the wheels then run oem toe settings.
I would if I was close enough and if I didn't have a ton of work to do myslef.
3. See #2
If it doesn't rain and the car is running problem free then yeah I will probably drive it. If it's just the plastic I would imagine it could be sealed but I'm not exactly sure what the psi is running through there.
Lol Andy, you know that one M3 in Overland Park with 42k that you posted here a bit ago, well I drove it today. I should say me and my dad drove it, he is the one looking at it. It was really nice, but had cloth seats ? for some reason. Not a deal-breaker, but maybe someone can clue me in: is cloth more common in an M3?
Related Threads
E46 Fanatics Forum
17.9M posts
592.5K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
