Rating:
Display Modes |
#141 |
Same problem here , would updated dme n would report back .
#142 |
Finally Fixed
After a long drawn out process my studder is finally fixed. I ask BMW of Mt Laurel to update the system and they claimed they did, and the problem continued. I then asked them for update information, (version number), and they could not provide a clear answer.
I took the car today to BMW of Atlantic City and dealt with Service Adviser Nick Vitanza, and Technician Jack who works on his team. Jack knew all about the problem and mentioned the update without me informing him. They updated the DME and EGS with version numbers : DME:7561526 and EGS 7558008, and the car is flawless. If anyone is in the tri-state area I highly recommenced seeing these gentlemen. Last edited by arich; 05-07-2013 at 01:00 PM. |
#143 |
For me all I have to do is click the dsc button and that fixs the problem. I think possibly the studer is related to the traction control unit tring to hold a safe traction on a fast acceleration, or possibly that is what's happening in my case and your car has the real stutter problem
![]() Last edited by blksab65; 05-08-2013 at 03:49 PM. |
#144 | |
#145 |
****ing stealerships cant never do **** right
Sent from my DROID RAZR using Bimmer App |
#146 | ||
Email I wrote to BMW of America:
Anybody in Central VA know of a dealership that's worth a damn? |
#147 |
Take it to an indy or flash it yourself.
#148 |
Modded ///Member
So I've had this hesitation between 2200-3000 for over a year now, had my vanos repaired (beisan) and had my dme flashed at an Indy shop, cleared adaptions numerous times, pulled the disa and it was 100% operational.
Long story short I see these flurosilicone disa o rings for sale on here from member MJlavelle http://forum.e46fanatics.com/showthread.php?p=15278802 I installed the o ring today, no pulsing no hesitation absolutely smooth pulling all the way through! Feels like a brand new car I can't believe this whole time it was a bs o ring.... |
#149 |
Glad u fix the problem
#150 |
Hm, I seem to be having these issues, and have been for quite some time. I've replaced air and fuel filters, all spark plugs, cooling system (preventative), checked the DISA and yet I still have stuttering. I've had the SES light come on once under load, but turning the car off, then back on solved that problem. I have a 2004 325Ci.
Fast forward a year. Driving home from the Tail of the Dragon and under normal load in mountain driving, SES light comes on. Pull over, stop/start car, light remains. Stutters almost exactly at 2800rpm, half throttle, no matter which gear I'm in (5sp manual tranny.) Found an Autozone and had the codes read, threw a P2240 error. Finally! I got an error code that can be read. Anyway, I have set an appointment with BMW dealer to have it reprogrammed for Wednesday, so hopefully this will solve my problems, and I can be added to the list. I'm also curious, the last time I had some work done, they noticed my car had Dinan software installed. If this is true, I will be very happy. When I drop off my car on Wednesday, I'll be sure to have them look into this.
#151 | ||
Glad to hear you finally figured it out though. Were you getting any kind of lean codes with the vacuum leak? Quote:
Unfortunately, I'm pretty sure you will lose your Dinan software when they update your DME. Good luck........Barry
![]() Last edited by mrmaico; 05-21-2013 at 01:38 PM. |
#152 |
Alright, the final report. Took it to Dreyer & Reinbold BMW South, here in Greenwood and first off, I was VERY pleased with this dealer. They treated me very well and were very courteous towards me.
Now, onto the repairs. They first ran a diagnostic and charged me for it, to find that it was throwing an O2 sensor error on Bank 2, but that was in the stored memory fault, and not necessarily the problem. They did find however that there were many software updates that it needed, and that this would solve the stutter issue. Got a call, and a final grand total of $203 later, the problem has been fixed! They reflashed my DME, and advised me to change the O2 sensor, but wanted ~$400 to change it. I can do it myself for that much ![]() So, another case of software updates solving this issue. Now, my question, is if my car has never been hooked up to any computer, why did it start happening? What caused the DME to get screwy in the first place? Any ideas?
#153 |
Damn really need to do this , but damn dealer wants 345 for a flash
#154 | |
Re: E46 2800 RPM Stutter Club
Sent from my Galaxy Nexus |
#155 | |
#156 |
Anybody knows the number for the latest update for a zhp ?
#157 |
#158 | |
“The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed.” |
#159 |
Thank you
