A few weeks ago, I purchased an M-Tech II Front Bumper from ASPTuning. I'm having trouble attaching the reinforcement bar (rebar) to the M-Tech Bumper. I'm using 8 expanding nuts and 8 bolts from BMW. When I attach one side of the rebar.. the other side lifts up in the air. I attempted to push the lifted part, down, but the expanding nuts popped out on the other side of the bumper.
I assume the bumper is after market. With my M bumper I had to put on the bar to the car first, then put the bumper on and I put 3 rivets at the top where the hood meets the bumper in the mid.
You must not be using large enough expanding rivets. They seem to be pulling out when you add force to them, if they are larger they will mushroom more and prevent it from pulling out. (that's what she said)
Hmm that could be a solution.. I just feel that I'm exerting more force on the bumper than what is normally needed.. It seems like the bumper wasn't made for my rebar? My bodyshop thinks an M3 rebar may fit differently? I know this is an aftermarket bumper but fitment looks WAY off.
I'm not too sure about this solution but I did read a few install issues regarding Mtech II's and the reinforcement bar sometimes needs to be replaced with a facelifted one. But I think I would try the few above mentioned solutions first before going and putting more $$ into getting a facelifted reinforcement bar.
I know with even a few of my own personal bumpers I have to leave the bar on, then stick the bumper on, and forget the rivets. Then push the bumper into place and usually that does the trick.
Cause everything seems to be pressure fitted into place so it won't fly out on you or all out but your call. I'm not suggesting it but I'm just giving you an option.
Hey man I had the EXACT same problem with my Euro-Spec bumper, but luckily I had also gotten these (BLIND RIVET part # 51118222901) as a backup. Use these with one of those manual rivet guns (Home Depot/Lowes, see below) and they should hold better than the screws. The rivet gun tips I had were too small for them, but I just ended up not using a tip at all. Worked like a charm. Let me know if you have any other questions.
your problem is in your second pictures. At the ends of the reinforcement bar, you should have a screw and a nut holding the bumper to the bar.
I know this, because I did my Mtech II install few weeks ago. I had no issues at all. If you are using rivets on the corners of the bars they will pop out like it is in you pictures #2.
I have a question..
I am trying to install mtech bumper on my facelifted sedan
and I am going to get the brackets but do i really need to get the hex bolts and the washers?
or can I just use generic bolt and washers that fits?
I had the same problem. Put the bar on the car first and just jam the bumper to fit over it and it should work out ok.
Related Threads
E46 Fanatics Forum
17.9M posts
592.3K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
