I tried to clear the error codes via PASoft to no avail. Is there another tried-and-true method that I can try to reset the light to see if it was a fluke? I am asking because nothing unusual happened before the DSC+Brakes lit up, and the drivability now is the same as before (besides the fact that DSC is now disabled).
If not, I guess the worst case scenario would be pulling up the driver's seat to replace the sensor. After extensive research on the forum and the web, it seems that the yaw rate sensor is called differently at different places (speed sensor, rotation rate sensor, yaw rate sensor, just to name a few). However, I have narrowed it down to 2 possible part numbers:
Were there any fellow members on E46 who had this issue before and replaced the part themselves? If so, would you kindly help by identifying the correct part that should be replaced? Also, were there any additional programming required after replacing the sensor?
I have the same problem. DSC and brake light (orange) turned on by itself at less than 40mph speed in a straight line, heard braking noise as if DSC engaged like in an uncontrolled maneuver. Fault code detected 5E38 Rotation Rate Sensor.
So, I believe it's the Acceleration Sensor aka Yaw sensor which would be this link:
Sorry to hear your problem has not been resolved. I am about to buy a new yaw sensor and I have a Bavavarian Technic unit to register the sensor to the car.
In your case, I wonder if the 5E19 and 5E26 caused the yaw sensor to give a faulty error codes due to the fact it was receiving incorrect information from the power supply sensors. Maybe your original yaw sensor is still good. Perhaps reset and clear the codes and see if the same codes (5E19 and 5E26) come back.
ECS Tunning is out of the yaw sensor. I will need to search for an alternate supplier.
I think so too but im not sure where the yaw sensor gets its power from?
I tried deleting the codes but they wont go away..
Try searching on google for the yaw sensor. I found a couple of sites a while ago but ecs had the best price on it.
Nobody has the speed sensor; not ECS or any of my favorite internet suppliers. The 2 BMW dealers close to home do not have it either. I drive with the DSC off to prevent the ABS from activating.
Does anyone know of a way to test the yaw sensor? I have the same problem, my stability control kicks on after driving for some time however My abs light is not on, I only get the Orange center indicator and the orange brake light and I have no abs light, the codes I have are
5D90 Wheel Speed Sensor Position Front Left
5E58 DSC Switch (most likely on because i deactivate the DSC)
5E4F Continuous Control
5E3C Rotation Rate Sensor Signal
5E38 Rotation Rate Sensor Circuit
I replaced the 2 front wheel speed sensors and just today reset the code so I will see if the problem comes back or not. Anyone?
Even after resetting the code it keeps coming back, im going to check out the wiring and see if that's the issue, if not then keep on researching for individual components test procedures.
I've been trying to hook my car up to INPA to monitor the yaw sensor output while driving, but haven't been able to get anything substantial. Right now the error is present at all times.
So i got everything out and got to the sensor, visually it looks fine. Wanted to do a quick diagnosis so i reseat the connection, plugged up the computer and the error is still present. Decided to check the sensor values and here is what I'm coming up with:
The sensor consistently reads extremely low. It is looking more and more like a bad sensor, i just hate the horror stories of those that have replaced it and the error came back. This was at a standstill, while driving it began hovering around -60 to -80
What should I be looking for if i go at it with a multimeter?
Here you go;
The sensor has a three pin connector with the following connections:
• 5V reference
• Signal
• Ground
The sensor receives a reference voltage of 5V from the MK60 control unit and provides a
signal output of approximately 0.25 to 4.65V depending on the amount and direction of
yaw. If the sensor is defective a constant voltage will be sent to the MK60.
Here you go;
• 5V reference
• Signal
• Ground
The sensor receives a reference voltage of 5V from the MK60 control unit and provides a signal output of approximately 0.25 to 4.65V depending on the amount and direction of yaw. If the sensor is defective a constant voltage will be sent to the MK60.
Anyone find anything on this yet? I've got some pin out for the dsc module both the mk20 and mk60, I'm not really sure what I have, according to some manuals I've read mk60 was only used from sept 01 on and have a 47 pin connector(MK20 has 43 pins), and last time I checked I could of sworn I check it out and I did have the 47 pin connector and my vehicle build is 4/01 so I need to verify this.
I will also be testing some wiring for possible shorts and testing some components as well, I really hope I don't have to replace nothing to expensive.
Related Threads
E46 Fanatics Forum
17.9M posts
592.8K members
Since 2001
A forum community dedicated to BMW E46, E90, and F30 owners and enthusiasts. Come join the discussion about M performance, turbo kits, engine swaps, builds, modifications, classifieds, troubleshooting, maintenance, and more!
