Old 05-01-2013, 06:25 PM   #1
wesleybmw
My Ride: 03' M3
Oil Pressure Sensor on M3
I have a flickering oil warning light on the dash and was told that it could be a faulty sensor. What's the best way to replace it and where is it located?
wesleybmw is offline   Reply With Quote
Old 05-02-2013, 06:55 AM   #2
markusmarkus
My Ride: 2001 330Ci
What color is the flickering light? If it is yellow it could be the sensor is going bad. It's an easy fix the next time you change your oil. If it's red that says that your oil pressure may be low or the oil pump may be failing.
markusmarkus is online now   Reply With Quote
Old 05-03-2013, 12:00 AM   #3
Cazz
My Ride: 2005 BMW M3
Oil level sensor:
http://forum.e46fanatics.com/showthread.php?t=600818
Oil pressure sensor:
http://forum.e46fanatics.com/showthread.php?t=709214
Cazz is offline   Reply With Quote
oil, pressure, sensor
