Old 11-10-2013, 04:42 AM   #1
av516
My Ride: 2006 M3 ZCP IB
well guess what happened today ...
timeline:
was on WOT (was warmed up of course) for 3 - 5 seconds
everything seems fine
1 minute later
steam was coming out of the driver side hood
pulled over immediately
upper radiator hose was disconnected
about the car
121K miles 04 ZHP steptronic (for now)
upper, lower radiator hose, water pump, EXP tank & cap, belts were replaced @ 100K miles (7-2011) (i guess it's not oem)
Parts are on the way i thought i'd share
av516 is offline   Reply With Quote
Old 11-10-2013, 11:02 AM   #2
kwoodbury94
My Ride: 02' 325ci
Good thing you were paying attention. could of been a real bad day, but you already knew that haha
kwoodbury94 is offline   Reply With Quote
Old 11-10-2013, 11:18 AM   #3
David McMahon
My Ride: '99 E38 740iL
Don't let it drip on your sandals!
David McMahon is offline   Reply With Quote
Old 11-10-2013, 01:43 PM   #4
NumbaOneNewb
My Ride: 2003 330CI Silver
I pulled over to see if I could help an e46 who had the same thing happen. Looks like the manufacture used both glue an that metal clamp to strap it to the hose end connector. The guy however had his car on during this whole time.
I was like, "um.... You might want to turn your car off. Whys your temp gauge showing?" He goes, "all the way red"
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 11-10-2013, 01:54 PM   #5
Serega91
My Ride: 03' WRX, 07' S2K
Originally Posted by av516 View Post
well guess what happened today...
same sh1t that always happens....
good thing you live in california
Serega91 is offline   Reply With Quote
Old 11-10-2013, 02:10 PM   #6
havnfun328
My Ride: '99 328i, '03 M5
Same exact thing happened to my buddy's ZHP at an autocross a few weeks ago. Turned out his motor mounts were toast (came out in pieces) and he thinks that may have pulled on the hose. Might be worth a check.
2003 E39 M5 Lemans Blue: Truly an amazing car
1999 E46 328i Bone stock 5-speed: Beater and Track Car
250K!!!!!!!!!!!!!!!!!!!
havnfun328 is offline   Reply With Quote
Old 11-10-2013, 05:38 PM   #7
av516
will do, thanks for the tip
Old 11-10-2013, 05:39 PM   #8
av516
he didn't want his newly done nails to be damaged
Old 11-10-2013, 05:43 PM   #9
NumbaOneNewb
Yeah the funny part was he told me he planned on fixing it by strapping on a hose clamp. I just shrugged and said "hope you didn't blow a head gasket man" because the whole time he had it running, steam was just billowing out of that hose. I can't understand why he don't turn it off. He even said he knew of this problem, had try to ghetto duct tape it already and was too busy to go get that clamp
Old 11-10-2013, 07:14 PM   #10
Efekkt
My Ride: 02 330ci
Some people just don't mind being stuck at the side of the road I guess....
Efekkt is offline   Reply With Quote
cooling
