E46 Xi Forum
Old 11-04-2013, 12:27 PM   #1
AndrewReaganM
My Ride: 02' 325xi OrientBlue
325xi Muffled Popping During Acceleration
So, I just purchased my first car a week ago (2002 325xi ~147,000 miles) and I am having a slight issue. When accelerating and turning left I hear a muffled popping until I reach a higher speed (more than 20 MPH). I know I need to replace both front control arms (I am in the process of purchasing them now because the bushings on the rear are almost nonexistent) but I would like to have your input on what is most likely causing this. Any help is appreciated!
Thanks, AndrewReaganM
AndrewReaganM is offline   Reply With Quote
Old 11-04-2013, 09:58 PM   #2
neutron325
My Ride: 03 325xi
Sounds like a CV joint failure.
not 100%, but thats my first impression.
03 325xi sport appearance, cold weather, Harman Kardon audio, etc
neutron325 is offline   Reply With Quote
Old 11-05-2013, 10:42 AM   #3
SamDoe1
My Ride: 4cyl of fury
I would guess ball joints and/or bushings. Do you get the sound under braking? If the sound is more of a clunk, it's likely a sway bar end link.
Old 11-10-2013, 08:30 AM   #4
ChadBMWxi
My Ride: 2004 330xi
Same thing happened to me, you need to replace your "center support mount" or some call it driveshaft center bearing. Severe popping vibration underneath you while accelerating through about 15mph? Yea it was bad Definitely check into it.
ChadBMWxi is offline   Reply With Quote
Old 11-10-2013, 08:35 AM   #5
ChadBMWxi
My Ride: 2004 330xi
Here's the one I bought from turner if you want to see copy and paste the link, good luck! Let me know how it goes!! Link:
support-bearing-e46-325xi-330xi.aspx
Old 12-31-2013, 02:29 AM   #6
AndrewReaganM
Thanks for the replies! I have been very busy lately (School...) and just replaced both front CV axles to find grease everywhere after 5 miles... Anyhow, I have managed to look under there at the Center Support bearing and WOW. It is obliterated so I will be ordering that soon. Again, Thank you for the responses and sorry about the delay!
-Andrew
Old 03-12-2014, 03:32 PM   #7
AndrewReaganM
I can confirm that made a enormous improvement in the way the car drives, and it got rid of the popping. It was a very easy job to do. Just get all four up high on jack stands, take off the exhaust (very easy), remove aluminum covers, and you are in there. Then remove the drive shaft from the guibo, mark everything then pull it apart. Very simple.
Don't hesitate to ask if you have any questions.
325, 325xi, muffled, vibration, xi
