Old 01-15-2014, 07:07 PM   #1
40gin
My Ride: BMW 330xi
Coolant issues after thermostat replacement!
So my thermostat was stuck open and my engine could never maintain heat in this cold NY winter, so I bought one off ebay: http://www.ebay.com/itm/BMW-E39-E46-...item564eefcccf
Yesterday I drained and flushed my coolant, replaced the thermostat, refilled the coolant with 50/50 mix and got my heat back, but my success was short lived. The engine temperature is perfect, but the new thermostat has this little hole in the front that kept squirting coolant into the fan which sprayed it all over the engine bay and caused white smoke. The whole looks like it's supposed to be there, but the original one doesn't have it. I asked the ebay store about it and they weren't much help, just offered a return. So I taped the hole, refilled the coolant, and thought I had temporarily fixed it. Wrong Today the coolant needed to be topped off, and the heat in my car disappeared (the engine temp is normal though). I drive a little bit and white smoke starts coming out of the radiator and my radiator light turns on, so I add more, and this happens over and over. I don't see any more leaks anywhere so I have no idea what the problem can be. Has anyone else experienced this after a thermostat replacement?_a_
40gin is offline   Reply With Quote
Old 01-25-2014, 04:43 PM   #2
MiikeOxlong
My Ride: 325i
never buy aftermarket bmw parts. i learned the hard way. you can find cheap oem parts on ebay. but if you have a coolant problem i would check your "heater inlet pipe" and your water pipe, they mold and leak
MiikeOxlong is offline   Reply With Quote
Old 03-23-2014, 09:59 AM   #3
Tacticaluke
I would certainly never buy aftermarket parts from eBay. Though they may be cheaper and a lot more affordable, they can't be trusted. Just in case I would check your water pump, it may not be the cause to your problem now, but it could be related someday with a faulty thermostat.
Tacticaluke is offline   Reply With Quote
Old 03-23-2014, 10:37 AM   #4
40gin
My Ride: BMW 330xi
Thanks for the responses guys. Turned out it was a faulty thermostat (my fault for buying off ebay) and also it was dripping coolant from the radiator hoses that attach to it. So to anyone doing this replacement, make sure you replace those hoses as well, or apply a sealant to the connections so the coolant doesn't leak out. Got mine from autozone and it did the trick. Been driving for a few months without any issues. Oh also the white smoke was the result from coolant spraying onto the radiator and then evaporating when it heated up. Cheers
coolant, cooling system, radiator, thermostat
