Old 05-21-2014, 08:45 AM   #1
SteveDub
My Ride: BMW 320cd M-Sport
What Led Rear Lights Fit my E46??
Hi,
I am a brand new BMW owner, my first ever one!!
I am a little confused around the different fitments of lights etc due to different facelifts. I need to replace the Rear Nearside LED Cluster on my 320cd E46 2004, as it has a few failed LEDs and I don't fancy pulling apart and trying to fix. Although I'm under the impression there are only certain ones that will fit..is this correct?? Or Do any of the LED type fit, say off the M3??
Sorry for the Newbie Q, I'm still learning about the differences between models!
Cheers,
Steve
SteveDub is offline   Reply With Quote
Old 05-23-2014, 06:59 PM   #2
sillieidiot
My Ride: '06 AW 330ci
Sorry but I don't understand your question at all. What do you mean by "rear nearside led cluster"?
I'm going to go out on a limb and assume that you are talking about the rear tail lights themselves. And you have OEM LEDs. With that, you can use any coupe lights as long as they are LEDs. So the M3 should work.
But if you take a picture of what you're talking about, I'll be able to confirm it for you.
Old 05-25-2014, 07:40 AM   #3
SteveDub
Hi, Thanks for your reply!
Sorry, I realised after joining that this is a predominantly an American forum, so we may have different terminologies. Yes passenger rear led light, seems like you have answered my original Q so thank you
another though..... are all the wiring setups that come with lights/on car the same for all LED types irrelevant of age/model??? I am looking for a replacement on eBay but don't want to buy the wrong wiring setup if these differ.
Thanks for your help,
Steve
Old 05-25-2014, 03:31 PM   #4
sillieidiot
you have a facelift coupe. you want to stick with OEM only. either from another facelift coupe or m3 (both 04+) with LED tails. you can't buy normal non-LED or aftermarket because the connector is different.
320cd, led, led problem, rear led, taillights
