BMW E46 Succesful engine swap with same ECU - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-21-2014, 02:31 PM   #1
Wichop
My Ride: 2001 BMW 320i
Hi, just want to let know the e46 fans that i bought a used engine for my car and has been swaped succesfully, my car which had very bad problems (heavy misfire, overheating, leaking oil, burning oil etc) needed the swap since the head and valve job costs around the same 1,500 dollars aprox, i would recommend getting a head gasket replacement only if it was your first overheating and you have only coolant problems, but the cost of the complete engine itself is very similar to the cylinder head repair, so its your choice, if you swap to a bigger engine you would need a new ecu and keys programmed to that engine, but you can reprogram your original ECU to operate with the new engine(just read that, havent tried it).
The engine i bought was a canadian 2.2l engine I6 from a 320i, it was swaped into my euro 320i which used the exact same engine size.
The reason i am posting this is because i want to note (since i found no info regarding this procedure in the forum) that you can use your same ECU and keys when performing an engine swap for the exact same engine as i did.
Wichop is offline   Reply With Quote
Old 03-21-2014, 08:01 PM   #2
Cavi Mike
Banned User
My Ride: 2000 328Ci
Send a message via AIM to Cavi Mike Send a message via MSN to Cavi Mike Send a message via Yahoo to Cavi Mike
We know this. The ECU has no way to tell what engine is in the car. The ECU doesn't communicate with the engine, it communicates with the sensors and the EWS. Why would you think a different engine wouldn't work?
Cavi Mike is offline   Reply With Quote
Old 03-21-2014, 11:05 PM   #3
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
You found nothing about it because everyone knows there no problem swapping just the engine. Since it's the same engine they will bolt up and connect up just fine. There is nothing unique from one engine to the next when they are made. The problem has always been the ECU is married to the EWS, keys and locks. That is why people are selling them as a sets on eBay. The problem there is with trying to get a new key. You need the registration for the vehicle that the ECU, EWS, key and locks came from with your name on it or BMW won't sell it to you, but that's another story.
scottjoh is offline   Reply With Quote
Old 03-22-2014, 08:25 AM   #4
BeMyWhip
My Ride: 01 BMW 330ci
Good job OP.
Glad your swap went well.
Welcome to the smart ass board where everyone here knocks what you do and
Have to one up you with what they know.
Did you do it yourself?
Always Mod!!!
Founder: 330Ci The 3 litre coupe
BeMyWhip is offline   Reply With Quote
Old 05-27-2014, 04:38 AM   #5
Many330i
My Ride: e90 M3
Originally Posted by bemywhip View Post
good job op.
have to one up you with what they know.
+1
Many330i is offline   Reply With Quote
Old 05-29-2014, 08:29 AM   #6
raptorman5174
My Ride: 330i ZHP
good job op.
+2
18 VMR CSL's
Koni
Eibach Sport Spring's
UUC Power Pullies
Sprint Booster
CCV Delete
3:38 rear diff
raptorman5174 is offline   Reply With Quote
ecu, engine, swap
