Old 08-31-2014, 01:16 PM   #1
Tate325xi
My Ride: 325xi 5MT
Review of Khoalty Headlight Lenses
Having just hit 100k, my E46 was looking and feeling a bit tired. I felt that one of the best ways to make it look newer was to fix my old, clouded headlight lenses. I tried several different headlamp restorer products, to no avail. After the third try, I decided it was time to replace the lenses. I called my dealer, and was told that OE replacements would be $160 for each side, and decided that $300 plus was way too much to spend on a project like this. After surfing around for a bit, I found Khoalty’s replacement lenses, which included both sides for just $80. I decided that for 1/4th of the price of the OE ones, it was worth a try.
Here’s a shot of my car before, with the cloudy lenses:
Comparison of the OEM lens and a new one from Khoalty:
One old and one new lens:
Overall the new lenses have been great. They are unbelievably easy to change, taking less than ten minutes for both. The Khoalty ones seem to be of the exact same quality as the OEM, and I noticed no difference in design between the two. They are equally heavy, and are identical as far as I can tell. When I first put them on, I noticed a bit of condensation in the light after going to the car wash, but after a lot of careful adjusting, it is now completely sealed from water. All things considered, I’d buy these again if I had to, and completely recommend the Khoalty lenses to anyone needing to replace theirs.
-Tate
Originally Posted by 217Bimmer View Post
sometimes i'm into it and my one hand gets tired, i try switching, but then it's like someone with lou gehrig's trying to peel a carrot.
Tate325xi is offline   Reply With Quote
Old 09-02-2014, 09:07 AM   #2
glhx
My Ride: 2002 330ci
The problem restoring them is the clear coat. It gets baked off and creates spot.
You have to sand all the clear coat off
and either reclear them,
replace them like you did
Or just re polish them till they are new and maintain them with polish every 6 months while washing your car
This has been re cleared.......a truck ran across it and put knife mark like scratches. These can always be restored
glhx is offline   Reply With Quote
headlight, khoalty, lens
