Old 10-05-2014, 02:18 PM   #1
pilotcorky
My Ride: '01 330i
Unhappy Coolant hose popped off... How screwed am I?
Hi everyone...
I was about a mile from home when I saw a spray of coolant come out from under the hood. The low coolant light came on but went away, so I (stupidly) decided to nurse it home.
Turns out the tab from the reservoir going to the hose that leads to the water pump had broken and the hose was loose. I'm going to redo the entire system since I just hit 100k and it was overdue anyways, but my question is...
How likely is it that the motor was overheated and is now FUBAR? Drove it for around 3 minutes, and there was still some coolant dripping from the tank so it wasn't bone dry... Temp gauge didn't budge but I'm not convinced it was reading anything since the pump might not have had any coolant in it...
pilotcorky is offline   Reply With Quote
Old 10-05-2014, 02:33 PM   #2
Gus330vrum
My Ride: 330ci
$500 for the engine lol..
Buy a hose,put it on. . Refill with water mixed with the left over coolant and drive... if it was overheated and engine toasted you'll notice coolant out the tailpipe and if water anywhere up stream you'll get misfire,hesitation. .
But best bet is a compression test with a rented tool from auto store near by.
Gus330vrum is offline   Reply With Quote
Old 10-05-2014, 02:59 PM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Did you keep an eye out on your temp gauge at all? If it was in the red it's iffy if it's done or not.
Replace both hoses, water pump, thermostat and tank. Price will be around $250 or so and can be done at home in under two hours if you really take your time.
Old 10-05-2014, 03:04 PM   #4
pilotcorky
My Ride: '01 330i
Temp gauge didn't budge. Think I'll do the cooling system and hope for the best...
Old 10-08-2014, 01:08 AM   #5
NumbaOneNewb
My Ride: 2003 330CI Silver
Repair the hose, run the car for a week and see if it's mysteriously losing coolant from unknown source. Then if everything is good, then go for the overhaul
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 10-08-2014, 03:30 AM   #6
Megalocnus
My Ride: 05 330i ZHP/MT
The engine temp sensor is on the block on the intake side of cylinder 6 - pretty far from the water pump. If the temp gauge didn't budge, there's pretty good chance that there's no damage due to overheating...
Megalocnus is offline   Reply With Quote
cooling, idiot, overheating, screwed, system
