Old 10-19-2014, 06:30 PM   #21
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Originally Posted by Tlvivo View Post
Three years and six months and i am replacing yet another diff... My theory, this 3.91 ratio diff wears off too quickly for my style of driving. Thoughts?
My first thought is you bought a Used diff as your replacement, so it finally wore out. I think if you had a brand new rebuilt diff using a fresh/new ring & pinion, we wouldn't be talking about this today.
At this point there's less chance of you keeping your Bimmer for a long long time, so I'd suggest looking for another used diff to re-install.
Good luck,
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 10-20-2014, 04:36 PM   #22
Tlvivo
My Ride: 320i Individual
Quite true Rob, it was second hand therefore I guess life expectancy would not have been as it would new. I will have you know that I am keeping this bimmer for as long as I can, I have my headaches with the car but man I live driving this thing!
Tlvivo is offline   Reply With Quote
diff, differential, driveline
