Old 01-03-2015, 02:29 PM   #21
Mattromiza9
My Ride: 330ci
Vacuum line from air pump to intake, vacuum line from intake to canister, and a cap on the intake. The cap was cracked bad. Also rip in disa valve o ring apon farther inspection. Cleaning injector(tips sitting in cleaner) and waiting for intake gaskets to come in. Gaskets looked alright except cylinder 1 looked sketchy on the gasket. Hope this helps people if they have the same issue. Taking the intake off only took 45 minutes and I did it at my house not at my work so you don't need a lift.
Mattromiza9 is offline   Reply With Quote
330ci, cold, confused, lean, misfire
