Old 01-11-2015, 10:15 AM   #1
Thate46Life
My Ride: 2000 BMW 323ci
323Ci Fan Trouble
Hi guys, I have an 00 323Ci and when I got it it need
ed the cooling system replaced. So I replaced it and the fan to. Sadly I think I went with an afterror market replacment. The problem I'm having is that it never turns on. Not when I turn ac on or when it gets hot. I checked the fuses today and they both are good. I tried to disconnect the temp sensor but I don't know which plug that is and if I recall correctly when we installed it the car was sending 12v, but can't be certain. Any help is greatly appreciated.
Thate46Life is offline   Reply With Quote
Old 01-11-2015, 10:24 AM   #2
Thate46Life
Here's some photos of the fan area also. Just found the temp. sensor and unplugged it and turned the car on and the fan didn't turn on.
ID:	586597   Click image for larger version
ID:	586598   Click image for larger version
Old 01-11-2015, 11:39 AM   #3
bmwbob89
My Ride: M-5 325 X3 528 740
What brand of fan did you buy? There is a big ass fuse for the fan. Did you check that one too.
bmwbob89 is offline   Reply With Quote
Old 01-11-2015, 02:27 PM   #4
Thate46Life
I can't remember what brand it is sadly but fairly sure it is not oem. And yes I checked to big 50 watt in the glove box.
Old 01-13-2015, 08:15 AM   #5
Thate46Life
Anyone have any idea?
Old 01-13-2015, 12:07 PM   #6
Weste46
My Ride: 2001 330ci
The temp sensor for this is in the lower radiator hose. I would start by replacing the sensor.
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 01-13-2015, 12:44 PM   #7
Thate46Life
Ok at least thats a place to start. Thanks.
Old 01-13-2015, 08:13 PM   #8
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Let us know what brand it is. I don't like it by the looks of the control module sticking out so much from it. Also check the big fuse as stated in the fuse box.
electric, fan, sensor, temp, temperature
