Old 05-04-2015, 07:09 PM   #1
jessesyoung
My Ride: 99 328i e46
No speedo, mpg gauge. Which sensor?
Finished a cooling system overhaul and immediately after lost speedo,mpg, and odometer. My abs light is on but that has been on for a while. Did I forget to plug something in? My assumption is that my rear sensor is bad, maybe even just dirty. But I don't know which sensor is for the speedo, as some forums say left and others say right side. I know my car has 1 sensor on my U.S. driver side that goes from the junction box to the wheel. And two sensors from the junction box on the passenger side. Any help out there?
jessesyoung is offline   Reply With Quote
Old 05-05-2015, 01:56 AM   #2
Loaded325i
My Ride: bmw 325i
The side with the two sensors one is for the brake the other is a wheel speed sensor. I'm not sure what tools you have at your disposal but you can either unplug the sensors at the harness connection at the wheel well. Or you can goto the abs module and unplug that...find the appropriate pin for the wheel speed sensor and use a multimeter to test the speed sensor. You'll need someone to spin the wheel for you obviously. I'm pretty sure the speed sensors generate a sine wave (AC) so make sure u set your meter accordingly. Make sure you don't spread the female connections inside as you can cause harness issues after your done. You need to just rest the probe on top of the pin.
It would be a lot better to use a scope to see the wave because multimeters cannot see frequencies very fast and will only give you an avg.
A mechanical hobbyist and car enthusiast
1971 Datsun 240z Devil Z red
1999 740il Titanium Silver
2004 BMW 325i CW,PP and Sports Package
1996 toyota avalon-263,000-Sold
2003 Lexus Is300-Sold
2000 Acura TL-Sold
2000 Accord 5 speed-Sold
Loaded325i is offline   Reply With Quote
abs, odometer, sensor, speedometer
