///M3 Forum
Old 08-24-2015, 03:08 PM   #1
shoe123
My Ride: BMW F30 328i
Should I Buy?
I found a 2004 bmw m3 smg with 100k miles on craigslist. is that high mileage and will it break down soon/easy? according to carfax everything looks good.... i dont want it to be towed or break down anytime soon. He is asking $14k, should i buy it? I know people say smg's are bad but I want an smg so dont judge haha
shoe123 is offline   Reply With Quote
Old 08-24-2015, 03:27 PM   #2
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
Ask to move this to the M3 sub forum because you'll get better info there.
Rob43
SUMMIT POINT WV 1:24:229 SCCA
Old 08-24-2015, 03:30 PM   #3
cvx5832
My Ride: 325Ci, 325Cic, C300
Have a PPI done. CarFax is near useless when it comes the nitty gritty of maintenance, or lack thereof.
cvx5832 is offline   Reply With Quote
Old 08-25-2015, 07:50 AM   #4
markusmarkus
My Ride: 2001 330Ci
Run away from SMG! They all fail and they are expensive to fix. Buy a 6-speed.
Old 08-25-2015, 07:56 AM   #5
choxor
My Ride: JDM
SMG is fine. The most common thing to go out is the pump motor, which you can get refurbed for about $250. Get a PPI done. Read the stickies on m3forum.net. Expect to pay a couple grand at least in preventative maintenance after you buy it.
Old 08-25-2015, 11:52 AM   #6
m3e46freak
My Ride: m Twee lol
Shut up.
****ing misinformed. 113k and no SMG issues, no salmon relay, no shutters that are abnormal and no leaks. *wood knocking*
Anyways, get the PPI done. I wish I bought a higher mileage e46 m3 for like 10 or 11k, then just ****ing get the subframe done/fluids/bushings for under 3k and only be in for 14k instead of ****ing paying 21k in 2012 and then doing all that fuking ****.
k done.
Rock Hard Abs Racing
ST Coil!
BREMBO
Apex!
Agency Power Headers!
Euro Cats!
Scorza Mufflers!
FRANK!! 311RWHP-260Torque
m3e46freak@yahoo.com for outside contacting
ebay/craigslist verified 100% FEEDBACK
m3forum 96% FEEDBACK
m3post/e46fanantics Great FEEDBACK
zpost/bimmerforum Great FEEDBACK
m3e46freak is offline   Reply With Quote
Old 09-06-2015, 08:44 AM   #7
ninohale
My Ride: 03 M3 / SG/DG SMG
Originally Posted by m3e46freak View Post
Shut up.
k done.
This.
ninohale is offline   Reply With Quote
buying an m3, smg
