Old 01-27-2016, 12:39 PM   #1
EthanMpower
My Ride: 2005 325i
One time issue or bigger problem?!?!
This morning I went to start my car and is was turning over but not firing. Possibly thinking fuel pump or CPS but the weird thing is I have no codes and the car started fine after trying a few times and did so the rest of the day uneventful. Is this a one time fluke like a piece of debris in an injector or could this be something bigger? I also have a very rough idle once a week or so where it feels like a severe miss or something but no codes!!Please help!!
EthanMpower is offline   Reply With Quote
Old 01-27-2016, 12:49 PM   #2
orb
orb's Avatar
My Ride: 325Ci
Could very likely be a soft failing fuel pump or a clogged fuel filter if neither of those has been replaced.
orb is offline   Reply With Quote
Old 01-27-2016, 12:55 PM   #3
cvx5832
My Ride: 325Ci, 325Cic, C300
When my FP had a soft fail I had a growl coming from the driver side floor, probably from the FPR. I also couldnt get to WOT on the freeway. Does it present any of these symptoms?
cvx5832 is online now   Reply With Quote
Old 01-27-2016, 01:47 PM   #4
EthanMpower
My Ride: 2005 325i
So far none of those symptoms no growl as of yet like i said it has been starting fine all today after this morning. Just curious if it could be some debris or a failing fuel pump?
Old 01-27-2016, 01:49 PM   #5
EthanMpower
My Ride: 2005 325i
As far as i know neither the pump nor the filter have been replaced i bought the car used and have slowly been working out the kinks made by the previous owner
Old 01-27-2016, 08:46 PM   #6
EthanMpower
My Ride: 2005 325i
I've noticed it's very sluggish at highway speeds poor throttle response.
Old 01-27-2016, 09:52 PM   #7
mleindek
My Ride: 2009 X5
I would change the fuel filter ASAP and see what happens, if it continues I would check the fuel pump.
After changing the fuel filter run a full tank of gas with a bottle of this:
https://www.fcpeuro.com/products/bmw...jA9BoChlPw_wcB
mleindek is offline   Reply With Quote
Old 01-28-2016, 09:35 AM   #8
markusmarkus
My Ride: 2001 330Ci
Meh! Use Techron. Same stuff. Buy it at the local parts store.
Old 01-29-2016, 01:13 AM   #9
cvx5832
Change the filter. I wouldn't be opposed to changing the pump too at the same time. Failing fuel pumps with the E46 is the rule rather than the exception.
Old 01-29-2016, 01:26 PM   #10
Rogue Pyro
My Ride: 2003 325i
If you have over 100k you might as well replace the fuel pump as PM, especially since you're showing signs of it starting to fail.
Rogue Pyro is offline   Reply With Quote
Old 02-10-2016, 02:05 PM   #11
EthanMpower
My Ride: 2005 325i
[Update] Changed the fuel pump and now everything seems to be working fine turns out to be a soft failing fuel pump just like yall said.
fuel pump, startup
