Old 11-17-2015, 08:41 AM   #21
markusmarkus
My Ride: 2001 330Ci
I wonder if the oil temp data (changes in resistance actually) are actually getting to the ECU. I'd check the wiring closely.
markusmarkus is online now   Reply With Quote
Old 11-17-2015, 09:32 AM   #22
jfoj
My Ride: 330CiC, M5, X5, E93
Loose connector, loose female terminals inside the connector, broken wire inside the wiring harness.
Old 05-15-2016, 10:46 AM   #23
fazalabbas
My Ride: 2002 E46 330xi
Oil pressure sensor
I just want to share how my P0198 got fixed.
I dont agree with this big tall picture in this thread. According to my very limited youtube base knowledge, Oil pressure Sensor (short/fat) is the Temperature Sensor. Or at least I thought it was oil temperature sensor.
Anyhow, I changed the oil pressure sensor of this picture calling it temperature sensor and my code is gone. I've driven for couple of days and it did not come back. It was a short/fat sensor that needed 24mm wrench
Just an FYI, I have changed oil sender unit or oil level sensor unit before above but that did not fix it
fazalabbas is offline   Reply With Quote
oil temperature, sensor
